Magura HS33 brakes, like new, silver, $75 per wheel
Very minty pre-2005 Magura HS33 brakes in silver that came off of a seldom used mountain bike. They are essentially like new and show very few signs of use at all, They have the old style (Pre-2005) lever that I think is better suited for unicycle use than the new style. HS33’s are the gold-standard brake for Maggies on your unicycle. The short lever blade with red adjustment wheel lets you dial-in the distance between the brake pads and the rim – on the fly, as you ride.
Comes with whatever brake line length you want, NEW black brake pads NEW black lever glade with TPA knob and are bled and tested for leaks. I also replace all worn parts with new so you get a world class unicycle brake for less dough than you’d pay for new.
These brakes will fit on any Kris Holm unicycle: 20, 24, 29 and 36 or any brand of unicycle (Hunter, Nimbus, etc) or bike that comes with dedicated four-bolt Magura mounts that look like this: http://www.inspiredbicycles.com/imag...own-mounts.jpg and a place to mount a lever under the saddle like this: http://www.unicycle.com/shopping/shopexd.asp?id=908
Comes with what you see in the pictures, so you will still need to get a set of Magura four bolt mounts like this : http://www.unicycle.com/shopping/shopexd.asp?id=907 to mount the brake on your unicycle. And, yes this brake is compatible with the KH spooner.
PAYMENT AND SHIPPING:
PAYPAL works best for me, but money orders are also ok.
$75 USD per wheel and add another $5 for USPS Priority Mail shipping in the US (2-3 days) and $10 for first class shipping to Canada (7-9 days). I ship the day after I receive funds.
BRAKE LINE LENGTH:
I’ll set up your brake with whatever length of brake line you want from 18" on up to 30". I can also help you determine the right length of brake line for your leg length and unicycle wheel size. Just ask.
BLEEDING / TESTING:
I flush and bleed all brakes with fresh Magura blue blood before I test, pack and ship your brake. Bleeding hydraulic brakes is messy and no fun - and so you won’t have to deal with fluid leaks, after I assemble and bleed them with fresh Magura blue blood, I test them all for leaks by putting the wheel cylinders into a custom test jig that I made. There, I’ll cycle the brake pistons under full power to check for leaks without having to bolt them up to a unicycle frame.
MORE BRAKES AND PARTS:
Want something else you don’t see here? I also have other Magura brake sets for sale (HS11, HS22 and more HS33’s on the way) and I repair Magura rim brakes if you have a set that leaks, needs repair or just bleeding.
PM me if you have questions. Also, a more direct way to communicate with me is e-mail at the e-mail address below.
Brycer1968
uniflasher@hotmail.com
