Magura HS33 rim brakes, black - showing very few signs of use. Original brake pads still show the round mold release “dots” on the wear faces.
Lever blades are KH spooner compatible.
These brakes will fit on any Kris Holm unicycle: 20, 24, 29 and 36 or any brand of unicycle (Hunter, Nimbus, etc) that comes with dedicated four-bolt Magura mounts that look like this: http://www.inspiredbicycles.com/imag...own-mounts.jpg
You will need Magura four bolt mounts like this: http://www.unicycle.com/unicycle-har…-brackets.html
You will also need a place to mount your brake lever under the saddle like this: http://www.unicycle.com/unicycle-har...yle-seats.html
PRICE:
$80 per wheel
PAYMENT AND SHIPPING:
Paypal works best for me, but money orders are also ok. My paypal address is: uniflasher@hotmail.com. Shipping will be $5 for USPS Priority Mail shipping in the US (2-3 days) and $10 for first class shipping to Canada (7-9 days). I ship the day after I receive funds.
BRAKE LINE LENGTH:
I’ll set up your brake with whatever length of brake line you want from 18" on up to some freaky long distance handlebar at 30" or more. If you want, I can also help you determine the right length of brake line for your leg length and unicycle wheel size. Just ask. I also change the cross over tube to a longer 10" line that clears 3.0" tires better.
BLEEDING / TESTING:
I flush and bleed all brakes with fresh Magura blue blood before I test, pack and ship your brake. Bleeding hydraulic brakes is messy and no fun - and so you won’t have to deal with fluid leaks, after I assemble and bleed them with fresh Magura blue blood, I test them all for leaks by putting the wheel cylinders into a custom test jig that I made. There, I’ll cycle the brake pistons under full power to check for proper function and leaks without having to bolt them up to a unicycle frame. I throw out any used parts that are worn or leaking so you don’t have to worry about buying a leaky worn out brake.
MORE BRAKES AND PARTS:
I have LOADS of both new and used HS33 and HS22 brakes in all sorts of fun retro colors and the basic black/grey too. I also have a good selection of my HS33/HS22 hybrid “franken-brakes” for 36” wheels too. also have several bleed kits and loads of other Magura rim brake stuff, new and used.
E-mail me if you want something different or digital pictures of something in particular.
Cheers,
Brycer1968
503-358-2252
