Magura Brakes
I was wondering, if I was going to buy some rim brakes for my MUni, would
I buy a Front or Rear brake set? that is assuming that I would want the
Magura HS33’s and not the 11’s or 66’s. Or is there a better brake set?
anyone who has ideas, im listening.
-M.A.D.
Max,
I don’t know what the better brake set is, but you definitely want the
Dooley? lever attachment like Kris Holm has. I’m in the process of finding
one, hopefully from unicycle.com. Without the attachment, it’s a stretch
to reach the brake, and usually when you need the brake, you’ll be hanging
onto the Miyata handle for dear life! (I found this to be the case on the
downhill at NUC - I didn’t dare to reach for the brake!)
Joe Merrill
In a message dated 7/25/01 12:59:27 PM Eastern Daylight Time,
dingeman@citilink.com writes:
> MUni, would I buy a Front or Rear brake set? that is assuming
> that I would want the Magura HS33’s and not the 11’s or 66’s. Or
> is there a better brake set? anyone who has ideas, im listening.
> -M.A.D.
Hi everyone,
These questions arose in my head too. Kris Holm runs a Magura Tomac brake, I have no clue where to find it, but since I am shooting for his signature cycle I really shouldn’t worry. He runs a front brake, a rear one would be way to long.
The Duel lever attachment you spoke of, allows you to grab the brake handle with more than one finger, as you would be able to without the attachment. It runs for around $12.00, and you can get them from unicycle.com. You have to cut the lever down, otherwise it will hang out too far and hit you in the leg. They come in lefty or righty.
If you have any other questions, do what I do, contact Kris Holm or John Drummond (unicycle.com) via e-mail, and they will give you answers, and they are very good people to deal with.
Evan
MUni wrote:
> Hi everyone,
    I can get a Tomac Front and Rear set and that is alot more than I
    want to pay considering I can get a Quicksilver (I think still a
    HS33) Front for about half the price, mostly becuase I can order
    just a front.
    I dont think that I will need one of these things. My dad
    will probably just weld one on for me or something like that
    if I need it.
    Max A. Dingemans, M.A.D.
Max,
I had no clue that the Tomacs were so expensive, mainly because I didn’t know where to get them. It really doesn’t matter for me, because like I said I’m getting the Kris Holm cycle (in a year) and I’ll arrange everthing with unicycle.com.
Without some sort of lever extender (duel levers) you will only be able to grab the normal lever with one finger, and you won’t want that, so you’ll have to weld it wider or order the extensor through unicycle.com.
-Evan
<snip>
The cables can be cut down to the right length. It’s not a nice job and
you need to be careful… but it can be done. The Magura Cult site -
http://www.execulink.com/~dtierney/wmc/Magura/contents.htm - has info on
bleeding the cables and makes mention of cutting them down -
http://www.execulink.com/~dtierney/wmc/Magura/tips_for_fitting.htm - but
it doesn’t sound like an easy task though.
Just checked and the Magura workshop manual tells you how to do it and
includes photos. It’s available for download @
http://www.magura.de/english/download/downloads.htm
Cheers, Neil
Someone was mentioning that the Tomacs only come in pairs. It actually
might not be a bad idea to get the pair anyway. I have broken one set of
brake levers because the uni smashed against a rock at a flukey angle.
-Kris — Neil Dunlop <n.dunlop@kildrummy.co.uk> wrote:
> <snip>
> Cheers, Neil
Do You Yahoo!? Make international calls for as low as $.04/minute with
Yahoo! Messenger http://phonecard.yahoo.com/
    That was me saying that I could only get the Tomacs In Pairs. are
    the Tomacs the only ones that have the Dual bolt system? or are
    the others more like the ones that come on a DM vortex. on the
    other hand getting Tomacs would make my dad have to figure out how
    to make a dual bolt system to weld on to the Uni.
    -Max A. Dingemans
> are the Tomacs the only ones that have the Dual bolt system?
None of the brakes actually come with the dual bolt system, but all are
compatible with it. The clamp mechanism is different, but all the
important parts of the brake (the brake housing) are the same. You can
even use the same clamp mechanism on the dual bolt design by taking off a
couple of parts, like the prong that fits behind the fork blade. It looks
a bit awkward though, compared to the real clamp, and you might have to go
to a store and buy some longer machine screws to make it fit. The dual
bolt design clamp can be purchased separately from the brakes and I don’t
think it is that expensive.
-Kris.
