magura brake mount
can someone tell me if these willl fit the magura HS11 brake, it says HS33 but i want to be sure
http://www.unicycle.uk.com/unicycle-spares/brakes/magura-brake-clamps.html
thanks
Yes M8. Those mounts will fit the slave cylinders for any Magura rim brake: HS11, HS22 or HS33. The only difference between the numbers is the type of lever that comes with them. The slaves are all the same.
Cheers,
Brycer
cheers, just ordered a clamp and level mount :smiley:
HS11 has less power than HS33, I’m using it on my KH24 and 29 with a custom spooner because not sure current KH spooner will fit. It’s OK and cheeper on 24 and 29 but I prefer to keep an HS33 on my 36"
