Mad4one comfort saddle -alternative?
This saddle is okay for relatively short rides, but after 7-8k I start to feel nimbless. I suspect it’s because it is a bit to soft and the curvature is a bit excessive.
I used to ride with Zero Fusion and between it and Mad4one comfort I would pick Zero, despite it being too rigid.
Is there anything in the middle?
I think about QX eleven.
Any suggestions?
The KH fusion One is the generation of flat saddle after the Zero and is more confortable. The shape was revised a little and the foam is also a little softer.
What are you using it for? Having a handlebar can help tons since you are able to distribute your weight between your hands and your butt. It also helps controlling the unicycle better.
I plan to use it on my 27.5er to ride on sidewalks and as a last mile transport, so it’s crucial to occupy as little space as possible. Tried the KH T-bar on 29er and had a feeling that it becomes bulky.
Ok, I’ll try to save $$ for One and a pivotal seatpost)
