Luna Bike Trial + DX32... how to get them apart?
Hello, im tryng to convert my trials uni to freestyle uni for the winter. But i cant get my luna bike trial tire of the DX32 rim. Does anywon has a trick?
Thanks
Maxtser
A/XTEAM - upcoming web page…
What tire are you planning on putting on it? The trials tires actually fit on a 19" trials rim. The tire says 20x2.5 but they lie. It is not a 20" tire and you don’t have a 20" rim. There aren’t any freestyle tires that will fit on a 19" trials rim.
Thoe luna’s are LIARS!
When they say 22psi: They’re LYING!
If I’m picturing your problem correctly and you’ve just got a really tight fit on the rim, try (deflating it of course, and) moving the side of the tyre you’re not trying to lever off into the middle of the rim. This part of the rim is deeper, so you’ll have a bit more to work with.
I drew a really crude diagram that probably won’t be of any use.
Andrew
Thanks to all!
I think ill stick with my luna for now, becaus of that 19 inch thing.
Max :roll_eyes:
http://www.unicyclist.com/forums/showthread.php?s=&threadid=31557&perpage=15&pagenumber=1
