I didn’t want to continue with the major thread jack on the the other thread so thought I’d start a new one. :o
On the topic of gearing schlumpfs lower, has anyone tried lacing a regular internally geared hub (like a Shimano Nexus 3 speed) into a 36er wheel, and then building a penquin frame to fit?
For those that don’t know, penguins are like giraffes but built with the pedals directly over the wheel rather than higher up on the frame. With a 36er wheel, you’d sit up a bit higher, but I don’t think it’d be crazy high. You could have a grip shifter on your handle bar setup, and the option of a low gear, direct gear, and high gear.
You’d be higher up, and mounting could be a bit tricky, but hey, if we’re talking about freewheeling uni’s, why not penguin 36ers?
on a 36" there should be enough room to mount short cranks and sprockets below the axle. The drive would have to be double sprocketed to keep the cranks in time. This would be much easier to ride.
I’ve wanted a penguin since I started unicycling. I think cranks below the axle would make a freewheel inverted penguin easier to ride, too. If I had the technical knowhow I’d make a freewheel version of the Huni-Rex.
Go to the thread copied below and scroll down to the bottom of the page. The detail in the photo is not real clear, but the caption says a person in the background has a Huni-Rex with a 29" wheel. I thought that was pretty interesting.
waalrus - I’m thoroughly impressed by your video…you’re kind of a trailblazer when you think about it.
It did make me chuckle, because to a non-unicyclist watching your video, I imagine their perception would be: pedal, pedal, pedal–coast–grab crotch–pedal, pedal, pedal–repeat.
My only issue with the huni rex style, is that I’m already running out of seat post on my normal 36er. If I drop the cranks another few inches, it’d be tough for anyone to ride…
FWIW, I’m not going to pursue this any time soon, just speculating.
