Loose bolts
As I was out enjoying a sunny day on my muni, I noticed an unusual sound coming from my uni. I discovered that the “pinch bolt” on the left side had come loose. I tightened it, and was off, only to find that 30 minutes later, it was loose again.
Has anyone had this experience, and what did you do to fix it.
its happened to me heaps of times before. i just put some lock tight on it, leave it for an hour or so and it will hold up for weeks.
tighten very hard!
Lubricate the bolt then tighten it as much as you can.
you should tighten it
if you jsut tighten it it will just come loose again, you really need to put something liek locktight on it to make sure it will stay in place nad not come loose at all.
