Loose Arms?
I am not really sure if this is a problem, but since I just got my KH-24 about 3 weeks ago, I wanted to check. The arms seem to be a little loose, as in, I can push them with my hand and they will shift, minimally though. I tried tightening them at the nubs, but they still shift. Is this normal? If not, how can I fix it.
                                               Jason
I’m dealing with this same problem on my KH24 right now. The problem appears to be that the axle isn’t fitting the hub correctly, so it slips around a little bit.
You can read about it in these two threads:
http://www.unicyclist.com/forums/showthread.php?s=&threadid=34174
http://www.unicyclist.com/forums/showthread.php?s=&threadid=33920
Hope your able to fix it :slight_smile:
