Looking for freewheel hub or wheel
I’m not sure at all what a ‘drift trike’ is, but I’d like to see what it does.
I’m thinking of putting this hub on a 24 Muni which currently has rim brakes. Might add the brake adapter, or spring for another frame. And then I need to get the back pad, the elbow pads, the butt pad, and go have fun…
I just bought and received an identical freewheel hub thanks to you. I never saw on the website what size the bearings were though. Are they 40mm or 42mm?
I have not personally measured this, but according the section in this post they are 40mm and we will need to either replace the bearings or get a shim to fit in the standard 42mm bearing holders. See the section for this particular hub.
