can someone show me what they look like i think they are on my pashley unicycle.
The Pashley has bearings which look like lollipops, but they are not problematic, because the bolts go from front to back instead of side to side. (Plus the frame is higher-quality than the cheap frames generally associated with lollipop bearings).
so will tey be stable enough for muni and abit of street not much just small drops and such like or is that a no go!!!.
The Pashley frame is pretty bomb-proof; heavy, but you definitely won’t have any problems with it.
ok cheers thanks for the help.craig
The Pashley will be fine for that. The more limiting factor is going to be the square taper hub and cranks.
