Hiya…got any suggestions for locking up a unicycle? I’ve got a little one
that’s about 3 feet tall (not a giraffe or anything) that I use for general
errands and riding around, but the only thing I can get a lock around is the
spokes in the wheel, but all you’d have to do is unscrew the wheel and take away
the frame. I thought of drilling a hole in the frame, but it would have to be a
pretty big hole so it might collapse when I ride it.
Possibly your idea of drilling a hole has some merit? Could you drill a small
hole and then place a chain link through it. That way you only require a small
hole but you still get the larger diameter in which to pass your uni lock. joel
Graham W. Boyes wrote:
> Hiya…got any suggestions for locking up a unicycle? I’ve got a little one > that’s about 3 feet tall (not a giraffe or anything) that I use for general > errands and riding around, but the only thing I can get a lock around is the > spokes in the wheel, but all you’d have to do is unscrew the wheel and take > away the frame. I thought of drilling a hole in the frame, but it would have > to be a pretty big hole so it might collapse when I ride it. > > Thanks in advance, > > – > -Butterfingers the Juggler http://members.xoom.com/_gwb/butterfingers > > --== Sent via Deja.comhttp://www.deja.com/ ==-- —Share what you know. Learn > what you don’t.—
maybe a machine shop could make you locking nuts like on a cars rim where you
need the key to take off the lugnut , this way you could lock it up around the
tire without worrying about someone taking the frame? don’t they sell stuff like
that for bikes? Blaine
