Just built up my new KH24, using as many exotic materials as I could for bling factor but more to keep the weight down. Weighs approximately 5kg (on my bathroom scales), as opposed to the stock KH24 which weighs 7.05kg according to krisholm.com.
mine is with Duro 3" tyre, Onza Tensile 140mm cranks, MG1 Weelgo pedals, ISIS Nimbus hub and Nimbus gel saddle. basix KH seat post, with a Magura HS11 it’s just 6.2 kg
SWallis CF base, rear bumper, handle.
Thomson Masterpiece Seatpost (80g)
KH 09 frame and rim
KH 08 Ti hub
Moments, to be replaced the Echo SL cranks when they come
MG1 welgos with Ti axles.
Duro wildlife
Eiserne Hand - I used a Specialised 24x2.4/3.0" inner tube. Wheelsmith straight 14G spokes with Wheelsmith ‘Duristan BN14’ nipples (pretty standard brass nipples, I think).
James - yes you can attach a Thomson post to a (non-SW) CF base using the top plate of the KH Adjustable post and the Thomson bolts. It works incredibly well, considering that these components weren’t designed to be compatible! I thought the bolts would work their way looose, but after 6 months or more of use, I’ve never had to. Napalm, I think you were asking about this kind of setup for your 36" recently. It works!
I’ll soon put a brake on and probably will change to 165mm cranks. I’ll weigh my new muni tomorrow on a more accurate balance at work.
Weighed the new muni at work and it is 5.6kg +/-0.1kg.
Mike I find your claimed weight of 5.05kg hard to believe. If the stock weight of a KH24 with Duro 3" tyre and JC Trailmix pedals is 7.05kg then you’ve only saved 390g! Difference in weight of tyres (weights from this page): 1495g-1250g=245g. Difference in pedals assuming that you changed to something like Odyssey PCs is 565g-420g=145g.
cool MUni Tony, now to go tubeless and use Ti spokes!
Not sure about the Venture cranks, I think milled Moments are a better option i.e. weight savings but still strong and durable. I don’t like the Wellgo’s much either especially on a MUni, too small a platform and not durable enough.
I’ve been using Nimbus Ventures on my KH20 for months and they are excellent cranks. Super strong and a fraction of the weight of Moments. Unless you’re doing huge drops Ventures will be plenty strong enough. I highly recommend them.
As for Wellgos we’ll see how they go. They have plenty of grip but I may change back to my trusty Keywin flats later on.
I don’t blame you Tony, I wouldn’t either. I didn’t mention the Hope QR, Addict Ti hub or 2009 KH freeride or 20" inner tube though The pedals are MKS Indoor Freestyle. Scales used were Alpine, with 20g accuracy. I’ve just re-weighed it to check (as the weight I gave was from memory) and it’s 4.91 kg. If I stripped the paint it could be 4.90
Definitely.
The QR weighs 51g but the bolt weights only 19g, so is the better option if you’ve not going to be adjusting frequently.
The size for a KH frame is 31.8mm.
