Light bicycle Unicus
It might be a hallucination from the AI… There’s only 35 spokes on the rim as well :zipper_mouth_face:
I had asked chatgpt to add the caption at the bottom and also to enhance/balance the color, and it did that, but also modified the uni features somewhat, mainly by adding the logos on the tire and rim, plus the rim texture.
Ah, now I see it, too.
Unretouched photo.
The main issue with trying to break the bead of the NR from the Unicus rim by standing on the tire, or applying pressure to both sides with your palms, is that the bead seat connection is located well *below* the rim’s sidewalls.
These methods typically fail - especially with the NR “lite” version - because the deflated tire’s extra thin sidewalls simply collapse above the rim’s side walls when applying downward force, even if wedge blocks are used.
I’ve tried numerous times, and with my very firm-soled 5.10 cycling shoes, right up against the rim, but they simply slide down the flimsy deflated tire sidewalls. The key issue isn’t how much downward force you apply, but how effectively that force reaches the bead. With the NR Lite’s flimsy sidewalls, the tire simply collapses above the rim instead of transmitting that force to the bead where it’s needed. It’s a force-transfer problem, not a lack-of-strength problem.
The exception might be the regular, heavier NR, with the much thicker and firmer sidewalls, that may offer enough support when stepping down with your weight on them, but I only have the Lite versions to go by.
The method I use is quick and easy, and doesn’t take much more time than removing an NR from the dominator rim. And the biggest positive for me - other than the very noticeable reduction/elimination of camber sensitivity - is that once inflated, the bead is set so strongly, that I can ride with total confidence. :slightly_smiling_face::+1::victory_hand:
Funny how AI placed them above the seat clamp when in reality they were below. It literally took reality to a higher level when enhancing the picture.
Anyway, since the first time you mentioned it I was wondering if (and doubting that) „suction“ was an adequate term to describe the phenomenon. I think it‘s rather the tyre bead having to overcome a very short section of a bigger rim diameter to in order leave the seat than it having to overcome a vacuum.
But I have to admit, suction is just so much snappier.
