Just got a new Nightrider tire and mounted it to my new Light bicycle 36" “Unicus” carbon rim. Look at that beautiful round profile, thanks to the 28mm inside rim diameter, which makes camber sensitivity a thing of the past. This morning’s test ride went great, and it seems to be an ideal setup. ![]()
That looks nice and round. Hope it works well for you. How does it compare to a wider rim resulting in a more squared tire shape?
Terry, what pressure is that tire pumped up to?
Also, will you please provide a link to the exact wheel you purchased? Light Bicycles offers so many options, it’s not obvious which wheel you purchased.
Thanks!
Edit: Maybe it is obvious…![]()
The 28 mm inside diameter is about 10 mm narrower than the nimbus Dominator 2 rim which does tend to flatten out the tread. One of the top reasons I purchased this carbon Rim was specifically because of the narrower inside diameter which will preserve the round profile and, the fact that it has a much more prominent bead hook, a deeper center channel, and taller sidewalls to confidently run the niightrider tire at full 65 psi. I run mine at about 52 to 55 psi, which is more than enough based on my weight.
Thanks, Terry! Which weave did you choose?
These were the ordering specs:
UNICUS-36 Hook UD Matte Disc 36H With Access Holes External Hole With Drain Holes With black decal.
One of these days I’d like to get myself a carbon hoop for my 36er. I’d probably option mine with a 12k weave and a glossy finish ![]()
That’s a very cool photo, there, hanging on your wall.
I’d love to have that rim for my 36er one day. Just need to get rid of my current 36er to fund the pruchase of the rim. Then build the uni - I think I have already all the parts except for the spokes (and the rim, obviously). I don’t like the deep cross section from an aesthetical point, but I’ll live with it. Kinda looks like a big tyre was put on top of a smaller one…
Here’s a video I just made showing my technique for easily breaking the bead of the Nimbus Nightrider tire mounted to the light bicycle 36-in carbon rim. Once inflated, it does create an extremely tight bead, and breaking the suction can be very difficult without the proper tools and technique. All tools you see in the video are easily carried in a backpack if you ever need to repair a flat or replace the tube.
Cool video. If I have to remove a stubborn tyre I lay the wheel down and step on the tyre, as close as possible to the rim. Do you think there is a reason not to do this with this setup, except for the risk of damaging the delicate carbon fiber?
The suction of the bead is so incredibly strong, that stepping on the tire will not release the bead. Your shoes or your feet will simply slide down the wall of the tire. Even the clamp used in the video, creates more tension that your feet could, and it still cannot break the tremendous suction. Only inserting the leading edge of a tire lever all the way into the small gap until the lever’s tip hits the rim bottom, can the bead be pushed away from the rim’s hook.
Terry - is your setup tubeless or with a tube? Was not obvious to me from the video. If a tube, what kind? Do you think there’s risk of some kind of pinch puncture with use of the clamp?
There are no tubeless 36-in tires, as all have a heavy wire bead. If you try to convert it to a tubeless setup you are playing with fire and risking serious injury or damage to your rim and tire if it blows off while you’re riding.
There are many lightweight tube options including TPU. I run a Vee tire lightweight 36" butyl tube, but im pretty sure they were discontinued.
The bottom line is, the installation and removal of the NR tire on the Lightbicycle carbon rim is now a snap, and doesn’t take much time at all to remove and/or mount the tire. But I will say, without doubt, once the bead seats onto the rim with the familiar “pops” during inflation, it’s on there solid and secure, even at the full 65psi.
Thanks for clarifying.
This is my DIY palm protector that prevents a regular lever from digging into your palm when downforce is required to push the lever tip fully between the tire bead and rim. I made it so it can be used with either the Pedro or the Park tool lever into the aluminum sleeve. Notice that the Park tool lever has a thinner leading edge, which I prefer as it is much easier to push it down between tire and rim.
Also a pic of the 2" hand clamp i bought from harbor freight for about $6. Easy to carry lever and clamp in backpack.
Let me disagree. This is how I remove my NR Light from my Unicus rim. You need stiff soles, though.
As is often the case, people read through a thread and then come up with totally unrelated questions… In this case I‘m wondering what those struts or whatever parallel to the seatpost are good for. I can’t quite see if they’re actual struts or rather tools or what. Curious to know their purpose.
Also, the rounder tyre profile should result in a larger wheel diameter and thus faster speed - I‘d be surprised if it was discernible, but who knows? Well, that would be you
. My guess rather is that the biggest difference is the way the uni behaves due to the smaller contact patch and reduced camber sensitivity along with the reduced inertia of the wheel.
Glad it worked for you.
“Struts”? Parallel to the seatpost? You must be referring to the plastic T holder that the seatpost rests in on the DIY uni stand in the photo. I made it a while back. I usually just snap the seatpost tube into it so the uni is suspended with the wheel off the ground.
