Leg Armor Size
Hi! I’m planning on sometime getting some 661 or roach leg armor. I’m wondering what size I should get. I’m about 5’6, and my inseam is about 29-30". My legs aren’t really skinny but they’re not too wide either. Does anyone know which size I should get?
Thanks! :slight_smile:
Nikki
I’m about 5’11" and I’ve got some Medium sized 661 knee and shin guards. They fit me really well although my legs are pretty long. I did a review of my 661 pads in the review forum and there’s a photo of them as well.
Good luck,
Andrew
I’m 5 ft 4 in and inseam 30 in. I wear a size small Roach leg armour and they are great. Better to err on a little long than a little short on the armour…small may be alright but medium might do it too… any chance you can try them on before buying?
Erin
I’m 5’8" with 29" inseam and wear 661 large (just a little long but cover my knees better); my no-fat nephew is about your height and age and wears 661 mediums.
i’m about 5’10" and i d’ont know my inseam (i’m guessing around 30’) but i wear a size large. I think it depends on your height/inseam, but i think more importantly how large in diameter you legs are. my friend (was 5’11") wore a medium and fit him fine until his calves and thighs got bigger, now they d’ont quite fit him. If you think you have medium or bigger legs and you’re over 5’7" i’d suggest the size large.
the easiest way is to simply try them on.:slight_smile:
Hope that helps,
Ryan
Re: Leg Armor Size
On Sun, 20 Oct 2002 19:34:41 -0500, nikkifrog
I’m 6’0" and 165 lbs, and I have size L. The length is just right, the
width is a little bit too small (the velcro patches are half-on,
half-off) but still OK.
You may want to check the size chart on www.sixsixone.com. The
“openings” are leg circumference measurements, I think.
Klaas Bil
I posted only a single copy of this message.
