learning unicycling
Hello,
What is the price of a unicycle ?
How long is it take for learning to make a ride ?
Are they special things to know for a quick start ?
Thanks for some explanation
Visit also our website www.grachtcrossers.be
the price of a uni… about 70$ to ummm alot
By a ride do u mean like 5 meters or 50 meters?
it took me like a week to ride 5 consisntently and about 2 weeks to ride 50 meters
PRACTICE!!
PRACTICE!!
PRACTICE!!
PRACTICE!!
PRACTICE!!
also hi and welcome to the forums
if u need any help just search for it on the forums
go to unicycle.com they have all sorts of stuff and a begginer erea
welcome
POW
You can get a good beginners Unicycle for around $70 US. CLICK HERE Ive been ridding about a month and i can competently ride for several miles, jump up small obstacles and drop down about a foot. For some people it will be a shorter learning period, while it for others it will be much longer.
A few tips from a recent new rider.
  1. Lean forward, i found i wasnt doing it enough and had to tell myself constantly to lean more forward.
  2. Keep your weight on the seat! It makes things much easier and wears you out a lot lot less.
  3. Wear some sort of gloves. I have scars on my palms now because I would fall forward every once in a while and get cut up by the gravel. A good pair of biking or leather gloves will save you from the cuts.
Good luck with the learning process.
Joseph
USA - www.unicycle.com
UK - www.unicycle.uk.com
NZ - www.unicycle.co.nz
Australia - www.unicycles.com.au
Sweden - www.unicycle.se
…name name a few online stores.
Good luck!
Andrew
uhmm, when you do learn how to ride, you gotta learn how to fall off too…just step off, i’ve NEVER fallen on my hands…so i don’t think the gloves are neccicary
Re: learning unicycling
“Twisthem488” <Twisthem488@NoEmail.Message.Poster.at.Unicyclist.com> writes:
Maybe you can. I bought a cheap uni. The pedals, rim and hub all
broke without doing anything more extreme than riding off curbs and
side mounts. The cheap clamp ruined the seatpost. The saddle and
tire were greatly improved by upgrading. The frame is still in use,
but that’s about it.
I would not recommend the very cheapest unicycles for an adult who
aspires to do more than simply ride forwards on flat ground. Kids who
don’t weigh much can probably get decent life out of a cheapie.
Ken
I would not recommend the very cheapest unicycles for an adult who aspires to do more than simply ride forwards on flat ground.
Well im using a Cocker Unistar CX. I weight 210 lbs and ive been doing 1’ drops with it. I tossed it in the air (on accident) had some major crashes, and hop around a lot. So far it seems to be holding up just fine. The only thing i did was modify the seat cause its not really suited for an adult size body.
And if he does buy a begginner unicycle why would you expect it to last to uni/freestyle standards? He’ll buy a bunch of them if he gets addicted anyway:D
Much has been said already. I can only add
<http://www.xs4all.nl/~klaasbil/uni_beginners.htm>.
Klaas Bil - Newsgroup Addict
“Deflating pi does not reduce calories, it just concentrates them. - billham”
Sorry Klaas, I did mean to link to your site as well.
Andrew
