freemount practice
Quote from NSYO:
57UR–on your static mount, what is the position of your pedals? From your post it sounds like they are at 6 & 12 (clock position), which would explain why you need to do a back pedal first. If your starting position is closer to 3 & 9 (assuming your right foot is back) then your back foot would be at somewhere between 3 & 4 and you should be able to just jump/step up onto the front pedal at 9 or 10. I don’t know if I misunderstood your post, or if any of this is making sense. I hope so! But in your last post you said you had 5 mounts, and your description is similar to my mount where the wheel is not completely static, but there is some forward motion.
(How do you get the quote in the little box. When I pressed the quote button it did not do what I thought it would, so I started over and did a cut and paste.)
Actually, according to what I read, my starting position for the freemount seems backwards in every way from what most people are explaining.
My right foot is VERY dominant, but I seem to need to let that foot do the jumping and forward push on the front pedal, because that’s how I start rolling almost 100% of the time (even from a standing wall mount), and that’s what feels comfortable. I know I should practice starting the ride with the other foot, but I always want to just GO.
For the freemount the wheel is not at 6 and 12, but more like you describe. Even with the top pedal already forward, my right foot (the jumping foot) seems to automatically pull the wheel back under me. The slight roll forward helped that a lot. I also have to keep reminding myself not to put weight on the left foot while I roll and jump at the same time.
If the foot on the back pedal is slightly up, is that 4 (maybe 5) or is that 8 (maybe 7)? I’m having difficulty figuring out which way the “clock” is facing. Is the front of the clock around to my left, or to my right?
I am practicing the freemount between two counters that are about elbow high. (I want to get the mount down fairly consistently before I try it out in the open. I’m tired of landing on my tail bone and, to be honest, I’m a bit afraid of breaking the thing - the tail bone. My luck has held up so far, but somewhere back in this thread, I read about somebody breaking their tail bone. I don’t need or want THAT.) So.. The counters are close enough that, yesterday, I think I would have had a few more successful attempts, but I ran into the counter. Three successful attempts yesterday, compared to 5 the day before. Today I will have more time, so I should get some better results.
I’m not falling off when I’m just riding. I have a good, smooth dismount off the back almost 100%. When I start learning something new, then I start falling again. I know that’s the way it is, but if I can keep that from happening, I will feel a lot better about it. Thus… the counter practice for the freemount.
Thanks everyone!
This is not only my favorite thread…
it’s my favorite place on the entire internet!!!
