Learning a giraffe?
Thanks for all the advice. I’m currently trying to train my reflexes by doing many front/rear dismounts so that it will be instinct when I begin to fall. I’m trying to remember not to lock my legs when dismounting.
There’s a car park near me that is mostly empty and it has a lamp post which I’m using to mount. I’ve still not taken the leap of faith to begin cycling yet. I’m still hesitant. Here’s a video:
Hi esm,
Do you have a video of you getting up onto your giraffe?
I have one I’ve had for years and not even climbed onto it yet. My plan was same as yours to do dismounts first before going for it.
I’m interested to follow your progress which will hopefully give me a needed nudge to try mine.
I’m still relatively new myself. I’ve ridden mine a handful of times, mostly over this summer.
To get on the giraffe, I use a tall step stool and the side of my van for support. I get my right foot on the crank and keep my weight on it so it doesn’t move under me, then I shove the saddle under me and get my other foot on the left pedal. Then after that it’s just a matter of riding off. It’s a little clumsy and definitely not perfect, but as long as it gets me in the saddle then it’s good enough :slightly_smiling_face:
Hopefully we will get another dry spell so I can practice again. I can post a video of mounting the giraffe then.
One piece of advice when using the ‘pole’ mount: make sure you hold the seat onto the pole when climbing up. It can very easily slip off and you will fall straight down onto the unicycle and land on it, potentially damaging it and getting injured too.
Personally, I think it’s best to practise in a wide open space. It’s better for you (and the unicycle) to fall into an open area rather than against something. The bash guard on my giraffe got bent landing onto low wall.
Another idea that can work well,
Use straps to fix firmly ladder to pole.
Make sure is very tight and secure!
It is very easy for me to get on using the ladder on the back of my rv.
Remember you are “catching” yourself from falling forward by peddeling.
Oww
The ground was wet, but I decided to give the giraffe another try today. I feel more confident getting onto it now - I’m not as shaky. I’ve tried different pedal positions when mounting too. I practiced a bit of idling - It feels like it only needs small pedal movements at this height. I’ve attached some videos. I Also managed ride it forward about 2 pedal turns, but I’m still hesitant and bailing too early. No videos of this unfortunately - maybe next time!
I reckon you have to keep at it and just that one time when you get a third pedal rotation, it is in your brain and the progress really begins. It reminds me a bit of when I wanted to learn Ultimate Wheel. It is naturally not as high, but just trusting you will sort of float above it was scary or the idea that my feet would be entangled in the holes in the wheel and I’d break my ankles.
But I must say when I see you hop off of the giraffe, it must be quite hard on the knees. Im too old for that now. After hopping off the front of my 29" (when stepping off the back fails), my knees already start complaining.
So definitely don’t give up, it will click at some point.
Besides, what helped me with UW, was that I found a fence of 50 metres along a quiet bike path, so I could hold on to it, while getting used to the UW motion. Just pushing off from a post, is more difficult. Maybe you can find a place along a building or something. Since you already can ride unicycle, you know how to push away from the wall.
Thanks for all the advice and encouragement folks. I was back on it today. I’m sometimes getting lucky and managing to pedal a few metres, but I still can’t legitimately say that I can ride it yet. I’ve uploaded more videos of my best attempts so far. I feel like I’m not dismounting in a controlled manner, but panicking. I should try to work on that. It is indeed a bit sore on the knees/back when I land. I’m 38 btw and unicycling is the most physical activity I’ve done tbh. We’ve to get some bad weather :cloud_with_rain: so I won’t be back on it until next week.
Guys I done it!
:trophy: Achievement unlocked: ride a giraffe unicycle :grinning_face:
I know there’s lots of arm flailing but I will work on that. I now need to practice dismounting to the rear and doing some turns.
Congratulations! :slightly_smiling_face: It’s a funny feeling, isn’t it?
Dismounting off the rear I usually slow down quite a bit and sort of let the giraffe continue ahead of me while I drop down vertically. It might take some getting used to but that’s my preferred dismount.
I find turning on a giraffe to be different from my usual riding, since turning on a giraffe is more of a “pivot” than a “lean” like how I usually turn, at least that’s how I imagine it to be
well done and after the dismounting, you will focus on freemounting and then taking it to a nice bike path to go for a few km ride? Hopefully where the wind isn’t too strong. and where tree branches aren’t too low :smiley:
I have no prob riding 10km on a 19", so riding a few on a giraffe, might not be that bad. Do you feel that it takes more energy with a chain from the pedals to the wheel?
I’m not sure. It certainly feels different. The nimbus giraffe isn’t a 1:1 ratio. It’s actually geared slightly. 32:28 teeth I think. A benefit of this is that it helps avoid the issue of bald spots on the tyre from idling.
It’s not really a practical unicycle tbh. I got it because it’s been a dream of mine to ride a giraffe ever since I first learned to ride a unicycle a year ago. I’m lucky to have a car park near me that is mostly empty. It’s a great place to practice stuff like this and it’s fortunate to have lamp posts to help me mount the giraffe! :slightly_smiling_face:
Well done.
Do you have a way to tension the chain, or take out the play/slack? In your videos it seems a little loose.
How is your riding on a non-giraffe wheel of the same size? I would say ride slower but deliberately controlled. As you gain more control that skill will/should translate directly to a giraffe.
Rear discounts are much easier for me. I find front dismount fron a giraffe to be harder on my body.
Glad you were able to achieve your goal. Time for some longer videos. :+1:
jeez …since you first learned a year ago. Impressive :+1:
Yes, there’s an adjustment for that. I wasn’t sure exactly how much tension the chain needs and I didn’t want to risk over-tightening it. Does anyone else have thoughts on that?
I don’t ride my 20" that often. I mostly use it to practice idling. There’s still so much that I have to learn. I still can’t ride backwards or hop/jump. I should practice more I guess.
Thanks. I’m ambitious to do all this stuff before I get too old for it. :smile:
Before getting too old… ur like 20 years younger than me at least. You can learn anything while you put ur mind to it.
:trophy: Achievement unlocked: rear dismount
I took your advice IvenBach and tightened the chain. It feels more responsive now. I pumped the tyre up from 20 to 30 psi too.
I’ve also practiced turning too and it’s starting to click. We’ve got some good weather forecast :sun_behind_cloud: so I can practice more. I’m enjoying documenting my progress here.
I can feel my knees while watching you jump down… but I reckon there is no way to get down in a slower fashion.
I think IvenBach was right about rear dismounts being easier on the body. I feels like I can bend my knees more. It takes quite a bit of confidence to do the rear dismount though!
