I however, did snatch the medal
Wrong, I did
and then I did
And I did again.
am I glad I woke up, so I could take the medal away from you.
Same
Im sorry to say, or not, but maybe it is better if you don’t wake up.
I just did
go back to sleep. it is still early. Don’t you have summer holiday?
I have welding camp, where I plan to convert a 16” frame into a 24” frame.
Instead of welding you can just cut the bottom parts off and put a narrower pipe in each arm, so you can adjust it for any unicycle, not limited to 16 and 24. and use those rings with a bolt that you can tighten with an Allen key, like on the top of the frame or on the handle bars.
I reckon the 29” frame is just as wide as the 19” frame, because of the tire clearance.
Or possibly a better welding project: build yourself an Ultimate Wheel like @Ulkicycling made for me. He is a pro welder and he can give you some good tips.
Too complicated, and I want a Muni.
Be the first to create a muni-UW. I will be your tester . a MUWni
That would certainly deserve a medal
Go back to sleep
When this is not a MUWni, what would you do with a real one ?
ez victory!
what victory?
ez victory! =
In the end zero victory!
yeah for you
