Does anyone out there know if a 24" LM with Duro 3" will fit in the old '05 KH? Its the blue frame with lower clearance and noodles with the gusset which wouldn’t fit the Gazz. I’ve got good potential deal on a used one but I’d rather not end up with a frame I can’t use. Thanks guys!
A wide rim will make a tire less tall so frame height should not be a problem, Just ask for a measurement between the legs of the KH frame to see if it is wide enough.
I asked this in the EB christmas thread but it got lost in the initial flood of posts but how is the side to side clearance with that Nimbus frame and LM rim?
There is about half an inch on either side between the rim and the frame leg.
