Lacing Pattern
I’m just building my first unicycle wheel. Does anyone have any
suggestions on better (i.e. stronger) lacing patterns for a unicycling
wheel, or does everyone just use the standard cross-3 pattern. It seems to
me that unicycle wheels probably suffer from a lot more lateral force, and
more symmetric front/back torque than a standard bicycle.
(I’m building a 24" wheel with a sun double wide rim)
Please let me know what you think,
Brad Davis, davis (at) enel (dot) ucalgary (dot) ca
Brad,
I’ve tried both 3-cross and 4-cross patterns; 3 cross is stiffer and seems
to hold up better in my experience.
> to me that unicycle wheels probably suffer from a lot more lateral
> force, and more symmetric front/back torque than a standard bicycle.
Do You Yahoo!? Make international calls for as low as $.04/minute with
Yahoo! Messenger http://phonecard.yahoo.com/
I’ve got a 4-cross pattern running on a supposedly bullet proof Dirtworks
Dice Two-Four rim (24"). I didn’t build it, but the guy who did has a
reputation for being a fantastic wheel builder. He said he’d never seen a
rim so strong before, and thought it could cope with the extra forces
associated with the 4-cross pattern. So far I haven’t had any problems
with it, including 2-3 foot drops and lots of sideways hopping. It doesn’t
even strain under harsh sideways mounts or standing on the rim sideways.
Whether this is a reflection of the rim or spoking I can’t say, however.
nic
For 48 spokes 4 cross is standard (same angle as 3 cross on 36).
Sometimes the spoke hole angle or eyelet angle stops you doing a higher
cross pattern.
e.g. 4 cross on a 36 spoke 24" might produce an unwanted bend in the spoke
just after the nipple.
A bigger hub flange and/or a smaller rim will exaggerate this angle - most
unicycle hub flanges are bigger than MTB or BMX flanges - so what might on
a bike might not work on a uni wheel.
I’ve built some Onza (Monty size rims) as 2 cross for this reason (with
12G spokes)
Also I think Semcycle (pro) wheels are built 1 cross!
Leo White
