Hello all, I apologize if this has already been covered in another post, but I did not find it in my search.
I am considering buying a KH26er that does not currently have a brake. I would like to install one and was hoping for some advice.
- What would be the best brake to install? Rim or hydraulic? I have not had any luck finding magura rim brakes for sale online and the disk brakes seem to be out of stock
- The frame does not have a disk brake mount so I assume I would need to buy a nimbus d brake attachment to make a disk brake work. Would the disk end up being inside or outside the frame with this option?
- Are spirit cranks necessary to add a hydraulic disk brake onto the kris holm? The unicycle currently has moment cranks.
- Also is there a specific hub I would need to make the brake work?
Any other advice regarding the brake situation is welcome! Thank you in advance!
