Ya i want to buy this unicycle but i dont know if it will support big drop like 6 feet high ?
If not can if possible you tell me other unicycle that will be good for drop ?
Thanks a lot !!
Thanks a lot !!
Hard to say since you didn’t give your weight, and we don’t know what your technique is like (Do you roll out, were you planning on dropping to flat or a sloped surface)
But judging by the kid part in your name I’ll say it should hold up to quite a few. But if the cranks and hub ever get screwed over (as they are the most likely part to break) then you can just replace it with profiles, or the new KH if they are out by then.
