Remember to check your equipment over once a while. I was just fooling around on my 29’er and noticed a pedal sound.
I found a bolt missing in the saddle and nearly all of them needed to be re-tightened. Same on my 36’er.
If you replace any of the saddle bolts, I recommend you use the 5mm hex ones instead of the 4mm (which come stock with a lot of unicycles). 5mm are less likely to deform over time as you re-tighten the bolts. If you are putting unusual amounts of pressure on the seat bolts (such as using a handle), then the bolts are going to have to be checked more frequently.
Been there
