I Just ran across this program (PHP/mySQL).
You need to have a dedicated server (Needs su access and some addional programs
installed)
Some features from their site:
two serving modes – IMG-based (for a standalone ad server) and embedded tags
(if you’re running OASIS on your regular Web server)
ability to serve “rich media” creatives
dual interfaces, one for admins and one for ad execs; the admin interface
is higher-powered, but the ad exec version is much better for novice users.
It is foolproof enough that you can actually let your ad execs onto the
system (something which we never felt we could do with our proprietary ad
serving system).
simple scheduling – start date, end date, number of impressions (if no
impressions specified, ad runs as a house ad, getting only “leftover”
inventory"), weighting of house campaigns
campaigns can be set to run on certain days of the week or certain hours
of the day
full support for third-party ad serving, including cache-busting mechanisms
hierarchical section management; sub-sections inherit campaigns and creatives
from parent sections, even as these sections are added and removed (of course,
no section with assigned campaigns can be removed)
simple section assignment for campaigns – just stick a campaign on any section
in the hierarchy, and it will propogate to all sub-sections. A campaign can also
be removed from sections, overriding the higher-up assignment
exclusive assignments – a campaign can be assigned to a section as an
“exclusive” and no other campaigns will be allowed to run on that section (our
proprietary system required us to remember these exclusive arrangements and that
becomes very difficult to do)
invoicing support - cost per click, CPM, fixed-rate campaigns; For each
campaign, you can record:
agency commissions
PO numbers
whether invoices have been sent
whether invoices have been paid
generate a single PDF file with multiple invoices for simple printing
creatives can have their own start and end dates
creatives can have section assignments that override those set by their
campaigns
creatives can have their own day of week, hour of day settings
full real-time monitoring of the delivery engine
up-to-the-hour reporting
email reporting
John R. Marshall JRM Studios.com - http://www.jrmstudios.com The Hotrodding
Network - http://www.hotrodding.net
