KH rollo+ k1 street crank
Can the rollos and the k1 streets fit together?
The rollos are only made for the Moments from KH.
Why would you want Rollos on k1 street cranks anyway?
maybe he wants them for huge foot room! that would be cool but id think they fit :frowning: But they do fit on light cranks
If you put them on any cranks other than moments you will probably hit your ankles. Moments have 1cm of offset and the rollo is 1cm wide so it’s effectively a straight crank. I think k1 light cranks and street cranks are already straight, so the disk will stick out farther than the pedal insert.
