KH or Onza muni....
Hey my brother is about to order one of these 2 and I cannot really tell him which one is better since I have no experience with them. So in you guys opinions which is better? Thanks alot.
Jeffrey
i did a TON of research comparing these two, and this is what i came up with
PROS OF KH24:
24x3 wheel
kh seat
well known, trusted brand (kris holm). guaranteed to be a decent uni, you only need to read a few reviews to know that.
at 449$, it is often considered the best bang for the buck, or the best off road uni under $800 (according to some).
basically indestructable; very tough
little part on cranks that bangs your ankles is now GONE
mount for a brake
CONS OF KH24:
heavy
comes with 170 mm cranks, which may be longer than you want
not in stock until early june (about)
PROS OF ONZA:
damn sexy
50$ cheaper
in stock right now
not quite as rugged and tough as the kh24, but still pretty close to indestructable
CONS OF ONZA:
only a 24x2.6 wheel. Many people have said that a 3 inch tyre instead of a 2.6 makes a big difference; you can ride with lower tire pressure and get more bounce :slight_smile:
not as well known/trusted as kh
hard to find reviews of it online
overall, i’d definitely have to say spend the extra 50 bucks like i did and get the kh. you simply cannot go wrong with a kh24. i’ve read every review about every part of the kh24, and there is nothing to not like. trust me, its the way to go, i’ve done the research.
-grant
i am unsure if you are talking bout the trials or the muni but from what i know
KH muni is better then the onza as the tyre is much better and the rim i think.
As for the trials i think they are the same.
i would recormend making your own from a nimbus frame(yuni) then onza hub/cranks dx32 rim what ever seat post and a kh seat if it was me.If you want to push the boat out go for the kh i would say that is if you can wait.
Ben
