I’m considering buying a KH frame for Christmas, and I’ve heard nothing bad about the longneck. After a little searching, however, I’ve found the only reason people get it is to avoid hitting their knees while riding trials. I am a purely street rider, and want to know if the longneck is worth it for me. I know the cost is the same, but does it weight more? Does it weigh less(because you can cut the seatpost shorter)?
Should I get the longneck? I’m a little over 6ft so I don’t see it being too tall for me. Is this what I’m looking for, or should I buy the shortneck frame? Is the longneck a worthwhile purchase?
yes, definitely if you are over 6 ft. It’s the same price and there are no real disadvantages unless you are short and the frame is too high for comfortable riding.
Advantages:
Really high seat if you want
cut seat post really short to shave weight
Puts seat clamp up under the seat and reduces it banging knees and other body parts.
edit: yes and It does look much better too like the other guys said
I would actually probably hit my knees on the clamp more often if it was up near the seat because that’s where my knees are when I stand up on the pedals. Often when landing SIF I will land with one foot on the pedal and then the seat will slam into my knee. I don’t ride trials so can’t comment there though. And I still do hit my knees on the clamp sometimes with a KH short neck frame. If you’re tall I’d get the longneck. Otherwise just get the shortneck.
Well my mind is pretty much made up then. I’m getting a longneck. I’m not a big fan of the blue, so I’m going to strip it. Do I need to put a clearcoat if it’s aluminium?
(I know absolutely nothing about different types of metal.)
it doesn´t cost much more than the usual kh.
If you´re a streetrider you´ve probably bent some seatposts or even cracked them, if you have a longneck you can cut a seat post of steal and save weight and make it stronger at the same time.
It looks nicer
It only weights 80 gram more than the regular kh.
I havnt seen one for real but I think they look kind of cool, cant say I realy love them (yet). Still getting one though, the weight saving is too apealing. Mine should hopefully come this week
