# KH hub play
**URL:** <https://unicyclist.com/t/kh-hub-play/64657>\
**Category:** Unicycles and Equipment\
**Created:** [June 30, 2004, 11:38pm UTC](https://unicyclist.com/t/kh-hub-play/64657 "2004-06-30T23:38:22Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![system](https://unicyclist.com/uploads/default/original/3X/d/4/d44cf5a6365651cf6b50671d1ff0c84adf0c7726.png) [@system](https://unicyclist.com/u/system)\
**Post date:** [June 30, 2004, 11:38pm UTC](https://unicyclist.com/t/kh-hub-play/64657/1 "2004-06-30T23:38:22Z")
</div>
I’ve ridden my new KH24 for maybe two weeks now. Is it usual for the
cranks to have play on the hub? Each crank moves a couple of mm as
measured at the pedal end. I’ve heard the solution (also to the
associated sound) is to grease the hub internally, but how can grease
resolve the play issue?
## Klaas Bil - Newsgroup Addict
I’m the kind of guy who spreads peanut butter with a peanut butter wrench. - cyberbellum
**Author:** ![jagur](https://unicyclist.com/user_avatar/unicyclist.com/jagur/32/48_2.png) [@jagur](https://unicyclist.com/u/jagur)\
**Post date:** [July 1, 2004, 12:14am UTC](https://unicyclist.com/t/kh-hub-play/64657/2 "2004-07-01T00:14:40Z")
</div>
the KH’s that i have ridden are all of the old 1st run and there was no movement like that at all. there have been about 5 threads now addressing this issue. this is the lot that was delayed and sent back because of a hub problem i belive..? if so it would seem that there is still a problem.
if it was me, i would send it back. play in the hub right out of the box cannot be tolerated. after all Taiwan got it right for the first shipment why soak up a mistake on the 2nd run.
**Author:** ![Murde\_Mental](https://unicyclist.com/user_avatar/unicyclist.com/murde_mental/32/304_2.png) [@Murde\_Mental](https://unicyclist.com/u/Murde_Mental)\
**Post date:** [July 1, 2004, 8:43am UTC](https://unicyclist.com/t/kh-hub-play/64657/3 "2004-07-01T08:43:54Z")
</div>
Same here…I’ve got the exact same problem with my kh hub…
I’m on a roll of bad luck…
**Author:** ![jason](https://unicyclist.com/user_avatar/unicyclist.com/jason/32/106_2.png) [@jason](https://unicyclist.com/u/jason)\
**Post date:** [July 1, 2004, 4:25pm UTC](https://unicyclist.com/t/kh-hub-play/64657/4 "2004-07-01T16:25:43Z")
</div>
I have one of the original, first run, KH24’s. I had some creaking on my spline until I put some anti-seize on but I’ve never had any play at all. Perhaps a defect?
