I was just curious, what size are the bearings on the KH trials wheelset? when i got mine, there were little metal shims on the bearings, i took them off because i would be mounting the wheelset on a bedford frame, not a KH frame. So ultimatley i'm asking, what is the size of the bearings that come on the kH trials wheelset? (MINUS THE METAL SHIMS)
Speaking of which, on a not-so-unrelated topic, does anyone know the bearing-to bearing spacing of a KH hub, profile, and suzue hub? I’m working on a simple little prototype frame that Sabin’s gonna help me test (he breaks parts a lot more than I do), and I need to know the bearing size on his wheel (he couldn’t tell) and if the bearing spacing is gonna be different from that of a profile hub, which is what I currently have the plans made for. These are gonna be aluminum fork legs, so I don’t think I can simply bend them into place like I do ith steel. Also, is the Suzue very different to the profile when it comes to bearing spacing?
Thanks for the help.
Sorry for the thread-jacking.
That will give you the hub dimensions but not the bearing spacing. But I think you can just use spacers to make the bearing spacing whatever you want. So I would just measure a KH or Yuni frame and use that dimension.
