Does anyone know what the KH24 and the UDC Max Traction Nimbus II 28" KH
seat weighs?
Anders Rustad
Trondheim, Norway
seat weighs?
Anders Rustad
Trondheim, Norway
I’d estimate the KH24 with brake to be about 18-20 pounds
friends KH24 16.75lbs = 7.61kgs (includes 6mm and 8mm allen wrenches, a couple wire ties, and a small amount of dirt)
I believe my Nimbus II 24" UDC blah is ~17lbs. It’s got a 2.6" tyre rather than a 3.0".
The 28" version with a 3.0" tyre probably doesn’t weight that much more.
i believe my nimbus 2 28inch, 24x3 is 6.5kg
Re: KH and UDC weight
My Nimbus 2, 24 inch frame, 24x3 Halo, 170 mm BE’s weighs in at 6.3
kg.
Caution: this is determined with the ‘delta’ method using bathroom
scales (digital, 0.1 kg resolution) so it’s likely to be inaccurate.
I measured my 29’er in the same way which resulted in 5.9 kg. But I
weighed the parts this morning with a professional laboratory scale
and they add up to 5590 grams. (Discrepancy 310 g.) So take the
results of the bathroom-scales-delta-method with a grain of salt
(about 1 milligram).
If the crank is moving then it really sounds as if it’s loose. - onewheeldave trying to pinpoint the cause of a clicking crank
Thanks for all the help
Ahh, so now people start posting their unicycle weights. I tried gathering this info a few months ago for what I thought would be a rather handy chart…but noone was interested then!
Andrew
On Mon, 15 Sep 2003 03:17:53 -0500, andrew_carter
Sorry Andrew the reason that I posted in this thread and not in yours
(which I do remember), is that I don’t think my weight data are
accurate enough for your chart. See the disclaimer in my reply.
