KH 20' or KH Double Crown
I am thinking of buying a new unicycle :smiley: and am looking at the KH 20’ and KH Double Crown. I found that the DC is less expensive than the standard 20’. Is there a reason for this? :thinking: And does the 20’ have any disadvantages compared to the Double Crown (besides extra rear fork)?
I ride mostly street and flatland with a little trials.
Thanks :slight_smile:
If you have any other uni brands and suggestions that would be helpful too.
Well the regular KH 20 is more versatile. It is worse for someone who is a beginner at flat imo. It is your choice but it is a bit heavier and not so good for trials either.
I would look into Impact unicycles; they have some nice stuff that weighs about the same and is a bit cheaper than KH. Except to pedals and maybe the cranks.
Maybe you want to get a custom uni. :wink: The groovy cranks from impact might suite you better for flatland and street. They can also be used for a bit of trial. The new 2010 KH seatpost imo is better. I have not tried the impact but KH is strong and pretty cheap. The naomi saddles from Impact are really nice!
I would mix and match a little bit if I were you but, as I said before it is your choice! :smiley:
I think the double crown is cheaper, as mybe they want to sell it off, as the double crown isn’t popular I think.
Thanks. Both of you guys have been really helpful. :slight_smile:
Have you decided yet, what you’re going to get?
Well I contacted unicycle.com.au (i think thats right) and they said they were taking the DC off the website because it was a slow seller! So I guess it will be the standard KH 20 BUT I am actually leaning towards the Impact Raegant unicycle.
I was just wondering, do you have to buy all the impact parts separately because I can’t find where they have entire constructed unicycles on their website.
well wherever your buying from, you should contact them and ask. I’m not sure where your buying from so I can’t tell you.
Check out http://unicycle.com.au/ for Impact parts, a wheel set is there.
Cool. Thanks.
They have all the Impact parts there. :wink:
I worked out the IMPACT is AU$758.45 and a KH20’ is AU$726 so there isn’t much difference in price. The question is now-
KH 20’ or IMPACT Raegant?
That’s all up to you; as I think posted before, I think you should mix it up a little bit. =D
