Last week I fitted a Kenda Nevegal 29x2.2 to my uni. It had a worn big apple before this.
Riding on roads with it pretty hard, it’s good. Quite aggressive tread but runs quite smooth when inflated hard. I reckon it would wear out quick tho.
I took it to a MTB place (Drumlanrig) and was quite surprised at how grippy it is. ++ This was my first muni on a 29" ++ There was a good 3 inches of mud over pretty much everything, but grip below. It did do a bit of sliding around sideways but that was mainly due to me being out of practise of uni-ing generally and not being used to the 29 fully.
When I first set off, I stopped to let some air out (it was still hard for the road), and rode off down the road to find the tracks. Aha! A track off to my right, turn quickly, tyre folds, pings back, throws me off. Stopped to put some air back in and it was ok. I don’t know what PSI it was at.
There was lots of rooty sections too and I kept coming off cos I thought the tyre would slip, and was expecting it to, but it didn’t slip once. Preparing for a slip was enough to throw me off.
Last night, I went out on the road again, well… the cycle path. I hadn’t put any more air back in, instantly I noticed it felt much better than other nights on cycle path. It was quite hard to turn tho, unless I was really smooth I could feel the tyre bending and wanting to ping me again. Then it threw me off into some gravel just cos I was going fast! Altho I think this was my fault really!
I think this is a good tyre as it is really grippy, has a good fit and grip on the rim, and is wide enough for a bit of bouncing. The sidewalls could be a wee bit thicker but from what I read/hear it is much better than other offerings.
I think for me personally, I need a wider rim and the tyre would be great.
Uni specs:
cheap 29" curved crown frame
127mm steel cranks
uni.com cro-mo hub
Rigida 29" rim - 27mm wide (I think - it’s quite narrow anyway!)
Kenda Nevegal 29" tyre
Kenda 29" innertube
wellgo V8 copy pedals
standard KH saddle - think I might upgrade to a nice flat street one soon!
T.
