K1 hub and Qu-Ax frame?
this frame http://www.einradladen.net/catalog/product_info.php?cPath=9&products_id=323&osCsid=86e0ecec4c56b5ddd564d454e1d2b227
and this hub http://www.einradladen.net/catalog/product_info.php?cPath=6&products_id=327&osCsid=86e0ecec4c56b5ddd564d454e1d2b227
will it work as is, or do i need to buy extra spacers for the hub?
i think they should fit fine, they both have 100mm bearing-bearing (centre) distance so i cant see any problems with it.
i was talking about the crank side bearing holder thickness. it has it on the frame’s page that it’s a little wide, so do i need extra spacers to put it on right?
I’m not sure about spacers, but I know the KH frame will work witht he hub and it’s not a whole lot expensiver.
Why not send them an email, they will probably be able to answer your question alot better than anyone here.
that sounds like a good idea, thanks.
