Jumping And Stalls
i was wondering how to make a big jump on a small thing and then how do you stay there and what is the best way to jump up curbs, sidways or head on?
Well for curbs if you are doing it static (not moving) then its easier sideways, if its a rolling hop you do it more head on.
thanks for the input
When im jumping up a curb, i usualy go almost straight on at it, but i ususally go more angled so i can get the right pedal position for hopping.
Static hopping i find it easier to do it sideways, but i can jump fowards too =p
Ummm, for stalls, i learned to do crank grabs first, then pedal grabs, most of the stuff i do with the seat under me, and then you really gotta lean into the object when you jump onto it, but if you do too much leaning your just gonna topple over.
For higher objects, SIF hopping is your best friend =p being able to tuck the unicycle up towards your chest really adds the extra jumping height you need.
any other advice it will be much appreacated
what type of advice do you need? more on hopping? types of hops? ways of stalling?
i want to know what will make me hop higher should i deflate or inflate the tire because im pretty light
For the tire pressure, your just gonna want to find your own amount, your gonna want some bounce, so you can really compress your tire and be able to spring up with it, but you dont want to go to low so your hitting your rim everytime.
thanx but i dont get how to bounce on your tire and then go one foot in the air
for me i put 23 psi in my tyre
