JS Question
I have an HTML form. When the form is filled in and the user presses the
submit button, a CGI script processes the submitted data. Everything is
OK up to here.
This is where I need help: After the form submission, I need to pop-up a
small window and print the success/failure page on that small pop-up
window. Does anyone have a JS code to do this?
Thanks in advance for any/all help.
Peter N. Go - mailto:peter@icthus.net
http://CGI-City.net http://ArticleCity.com
http://ZenSearch.com http://BannerBuild.com
http://RegisterGuy.com http://BudgetWebHost.com
http://NewsCuts.com http://FreeMailWeb.com
2,500 Qualified Visitors to your website for only $25.
http://www.icthus.net/pay-per-click/
Accept Credit Cards Online. Run An Affiliate Program.
http://www.icthus.net/cgi-city/clickbank.html
Re: JS Question
Generally, your CGI script will return to the browser a success / failure
page.
Re: JS Question
> page.
Thanks, but I already know that. What I need to figure out is how to
make the success/failure page appear in a pop-up window.
Re: JS Question
>> page.
How about just adding something like this for the scripts results page?
if (success) {
echo “normal javascript popup code with script.cgi?success=yes”;
} elseif (failure) {
echo “normal javascript popup code with script.cgi?success=no”;
John R. Marshall - Web Developer
JRM Studios - http://www.jrmstudios.com
The Hotrodding Network - http://www.hotrodding.net
Re: JS Question
> if (success) {
Never thought about that but it looks like it can work.
Will give it a try. Thanks.
Re: JS Question
> > page.
<FORM target=“INSERT_POPUP_WINDOW_NAME_HERE” action=“etc”>
-Mike K.
Re: JS Question
Mike,
This will only work IF the pop-up window is already popped open.
Otherwise, it opens a whole new browser window.
Re: JS Question
> Mike,
Correct, it will open a named window.
You could also use something like:
<form onClick=“javascript:window.open(etc, etc)”>
or is it onSubmit?
Can you tell I haven’t written any code in 2 months? :-/
-Mike K.
Re: JS Question
> or is it onSubmit?
OK, I’ll try these as well.
Can you tell, inspite of being a bounty-programmer, I really know
nothing about JS?
Re: JS Question
> nothing about JS?
I’ve only used JS when absolutely necessary, and never bothered to
“learn” it properly. I know how to accomplish a bit with it, but it
doesn’t come naturally to me like perl, PHP, C++, java do.
-Mike K.
Re: JS Question
Likewise. I only use it if I am being forced to use it :slight_smile:
Re: JS Question
> nothing about JS?
It’s because Javascript is the root of all evil! :wink:
The only usefull thing in js I can think of are alert boxes asking are you
sure you want to delete this.
