Has anyone thought of making hubs that are ISIS compatible?. Some members of the mountain bike industry have adopted this new type of splined bottom bracket and cranks (Race Face being one).
I’m wondering if this kind of hub could be manufactured. The blueprints/drawings should be readily available. Any CNC types out there?
the only one i know of is the DM uni,it comes w/a splinded hub but i’m not sure if it is ISIS
Yes this is a possibility. I started working with Raceface on this one,
but there are a couple of issues:
Volume. Profile has put quite a bit of work into producing their hub,
which works great despite the squeakiness. It’s hard to convince a
namebrand manufacturer to commit time to this small market and it’s
awesome that Profile has been making these cranksets. -
Expense. I think that one of the most important thing for the growth of
our sport is to make the unis less expensive, because so many people
are not able or willing to spend $1500 on a unicycle. ISIS aren’t
always expensive but often are quite expensive. Stay tuned for a less
expensive pinch-splined crankset, coming soon… -
Design. ISIS cranks are tapered splines. Non-tapered splines are
actually a better design for a unicycle, in my opinion, because they
allow everything to nest together on the axle (ie you slide the
bearings and cranks on and it all just fits without any space due to
the taper. This could be worked around with the ISIS so it’s not a
really huge factor. -
Crank lengths. Right now I don’t know of any available super-short ISIS
cranks to fit the Monty Trials setup. In contrast, short BMX cranks are
more easily obtained. Custom-making short crank arms would definately
put the cost through the roof.
-Kris Holm.
> splined bottom bracket and cranks (Race Face being one). I’m wondering
> Drewnicycle Posted via the Unicyclist Community -
> http://unicyclist.com/forums
> ___________________________________________________________________-
> ________
> rec.sport.unicycling mailing list -
> www.unicycling.org/mailman/listinfo/rsu
Do You Yahoo!? Send FREE video emails in Yahoo! Mail!
http://promo.yahoo.com/videomail/
MMM Raceface:D
I never even thought about the crank length issue. It seems that there is no middle ground with hubs and cranks. You can go low end or high end. I was thinking that an ISIS hub could be used with more crank’s etc. offering a little more middle ground.
It’s great that a company such as Raceface is even considering something…
try machining one!
The isis design is a freely used design, and the blueprints can be downloaded at www.isisdrive.com
I have thought about the possibility of getting a hub machined up with an isis spline on it! I am also investigating the possibility of converting a set of mony cranks to isis spline, but i dont think its possible!
Food for thought!
James
I’ve thought about it. Blueprints would be the first step. The ISIS plans are easy enough to get but I don’t know where to get plans for a hub. Any ideas?
I bought a Suzue hub from unicycle.com and measured it. It only cost $25 or so. I wanted it for the axle which, as it turns out, I am unable to use.
The DM hub is not ISIS. It uses an 8 spline pattern that is compatible with the Bulletproof BMX cranks.
The ISIS spindles for XC bikes are hollow. I have not seen the ISIS spindles for freeride bikes yet to see of those spindles are also hollow. If the freeride spindles are hollow then an ISIS hub for muni could also be hollow which would save some weight. Lighter and stronger is a good combination.
But the big question is, how do you make an ISIS muni hub economically?
john_childs
freeride isis!
the isis hubs for freeriding are hollow, but have a smaller bolt to secure cranks, allowing for more diameter of metal in the axel and a stronger set up. but is still doesnt weigh much. Companies like race race, specialized, truitive etc all use the isis spline for their downhill and trials cranks. Anyone seen ryanleech riding trials bikes, he uses an isis spline, so im sure if it can take him, it can take us!
James
