is it worth it getting a 24"?
It’s not a question of strength; more a question of market. Tiny market, and the vast majority of users are more concerned with looks and a comfy ride. A novelty cycle. For those of us that would like a lighter, faster tire, like me, we’re a pretty small minority. At least the newer generation of 36" tires are a little lighter. I would love a skinny version.
Hub width isn’t an issue, but tire diameter is. You can change the tire to something within the 618mm for racing, though you might not want it for the trails. You can probably find some tires that are small enough and still have decent tread on them, though.
A narrow hub and lower Q-factor aren’t very important until you start getting really into racing and lots of really fast pedaling. There are two components to Q-factor; hub width and offset or “flare” of the cranks. Most cranks aren’t straight; they have some amount of angle to them, either to clear other parts of a bike. or to move your feet a little bit away from the hub (which can be a plus for unicycles in non-speed situations). Fully straight hubs can give you a tendency to catch your heels on the hub as they go around.
So if racing for fun, just make sure your tire is small enough, and your cranks aren’t shorter than 125mm. A lighter wheel, skinnier tire, etc. won’t make a noticeable difference unless you’re really training A LOT.
Setonix had mentioned a racing tire, which automatically snapped my mind into narrow Q-factor road and racing mode. Bicycle road riders and racers insist on a narrow Q-factor (make no mistake about that!) but even mountain bike riders have their width limits, too, as riding a wide Q-factor mountain bike is said to be like riding a horse. Indeed, control and width management of the Q-factor has brought about the more recent mountain bike gear train switchover from triple to double cranksets and sometimes even to single cranks to physically move the chain sideways away from ever-wider mountain bike rear tires and from even wider 5+ inch width snow and loose sand tires, which in turn caused the development (and bicycle industry promotion, naturally) of 11+ speed cassettes, which in turn could soon bring about yet another increase in rear hub width (although that is already well underway) and all of those changes just to avoid having the Q-factor of the crankset get any wider than it now is. Do not mess with the ever-precious Q-factor!
And yes, johnfoss, you are right about an extra-narrow uni Q-factor being better adapted for specialty use, for unicycle racing and nimble tricks. My recently acquired beginners uni has ordinary 100mm hub bearing spacing which could probably do about 99% of everything I intend to do.
Interesting! In that case unless Setonix is planning or considering getting serious about this, perhaps a Muni style 24" uni might make more sense? Is that a potential takeaway from this advice?
My thinking is that while the super skinny tyre options will not be an option, he would still have a wide range of tyres from “relatively” fast, road style tyres, up to big/fat tyres, because the Muni-style unis tend to have wide clearance ( e.g. a URC/mad4one 24" has clearance for up to a 4.0 inch tyre). Thus, with a simple change of tyre, such a unicycle should be fairly usable for a range of disciplines? Or am I stretching the what you said too far?
I suppose it is good advice. When I signed up for the last championships I decided against buying a 24, because a German uni-friend pointed out that I would probably ride it once in my life and the bigger wheels are more comfy when riding longer distances. But lately when riding with my 5 yr old, I found that the 26" is already too fast for her sometimes and the 19" trials is certainly too slow.
Orginally I wanted to buy this 24": https://www.einradladen.com/507mm-24-Inch-Nimbus-ISIS-Muni-Orange
But they said that even though it is a 24" the tire makes it too big a diameter for the championship. I really like that stability of a muni tire, though the idea of riding the 5km on a 24" next year is also cool.
Potentially I could go for this one :
When I want to ride in the forest, I’d take the 26" or 29" anyways.
It is good my wife will go on holiday back to Thailand 2 weeks before me, so I can quietly order it without her ever finding out ^_^.
Yeah, but how much can they be nuts about Q-factor while riding on 4-5" tires? :stuck_out_tongue:
Yup. Basically all of the unicycles I ever used for Track were around 100mm hubs, or whatever was typical for Miyatas and similar cycles in the 80-2000s. I had a Track uni with a narrow tire, but it was built on a modified-but-normal-width Miyata hub. Worked all right for me, but at the elite level, I can see squeezing out a little more efficiency with my feet closer together.
The question with that one is can you fit a “small” enough tire on it? Any 24x3 tire will have too big a diameter for Track, so it might take some research or experimentation.
That is what I most likely would get to replace my old Miyata if I had to do that today. Note that it comes with a 2.1" tire, which also might be too big for Track. But you should be able to find tires that will fit and be the right size, without problems.
Yeah, fat bikes became the rage several years ago, very different, and I finally just had to try one, so a few years ago I got a new 2016 SE F@R 26 https://mountain-bikes.club/shop/se-fr-26-fat-bike-2016/ I keep it clean and maintained but I do not ride it often, out in a field by my house and on some local unpaved roads ranging from a bit to considerably rougher than gravel with maybe 20 psi or less in the tires, very cushy. It is fun once in a while, glad I got one, but for me it is not an everyday ride.
Here is the uni he wants https://www.einradladen.com/507mm-24-Inch-Nimbus-ISIS-Muni-Orange It has a 75-507 knobby tire on a 42mm
presumably outside width rim (= ~36mm inside width rim) and has 150mm cranks.
Here is the alternative https://www.einradladen.com/507mm-24-Inch-Unicycle-Nimbus-II-ISIS It has a 54-507 slick tire on a rim of unknown width but presumably narrower than the uni he wants and it has 125mm cranks.
IUF regulations for 24 Class racing unis allow a wheel of 618mm maximum diameter and cranks of 125mm minimum length. The 54-507 tire is IUF 24 Class legal; (54mm x 2) + 507mm = 615mm, 3mm less than IUF maximum diameter and the 125mm cranks are at the IUF minimum length.
Get the uni he wants, purchase a 54-507 slick tire, tube and a set of 125mm cranks. The 54-507 tire on the ~36mm internal width rim of the uni he wants will produce a slightly squishy racing tire but much stiffer than the original 75-507 tire on the same rim. Swap 150mm and 125mm cranks.
2B.2 Unicycles
Only standard unicycles may be used. Riders may use different unicycles for different racing events, as long as all comply with the rules for events in which they are entered.
For events divided by wheel size, there is a maximum allowable tire diameter and minimum crank arm length for each category:
Unicycle Class Max Diameter Min Crank Length Transmission
16 Class 418mm 89mm standard
20 Class 518mm 100mm standard
24 Class 618mm 125mm standard
29 Class 778mm No limit standard
Unlimited Class No limit No limit unlimited
For any tire in question, its outside diameter must be accurately measured.
Crank arm length is measured from the center of the wheel axle to the center of the pedal axle. Longer sizes may be used.
In all track racing events on standard unicycles, shoes must not be fixed to the pedals in any way (no click-in pedals, toe clips, tape, magnets or similar).
Question: How is “standard unicycle” defined?
A unicycle in its simple original form: a wheel, a pair of pedals and a saddle. So no brakes, no handle bar, no gear, nothing extra.
Wrong. Handlebars, and brakes are allowed on a standard unicycle. For all practical purposes, a standard unicycle has no schlumpf, isn’t a giraffe, Hunirex or Freewheel.
IUF Rulebook:
What about the restriction on the width of the wheel. I was told that a muni 24 has too wide a tire, but I havent found the permitted IUF tire widths.
No width restriction. It is because a muni size tyre on a 24 inch rim will have too big a diameter to comply.
BTW Here is a related thread discussing why standard 24 wheel sizes are different for basketball from track unicycles.
The word “standard” can have different meanings or translations. In a strict sense, standard could mean IUF has designed a racing unicycle and that every racing unicycle must conform to those IUF standard racing specifications or that each and every racing unicycle must be and look exactly the same. Or in a more practical sense, it could mean no alteration or modification of a unicycle manufacturer’s standard design. Or it could simply mean a unicycle must have one wheel, one seat and one set of cranks PROVIDED the wheel is not too big in diameter and the cranks are not too short, that modifications within IUF limits are allowed.
It is better to first know what “standard” means before making an expensive long distance trip to somewhere to only then discover that your unicycle does not have standard specifications and so does not qualify to be raced.
That’s why the IUF has a rulebook, and there is a section:
Defining everything from “Age” over “Freewheel” and “Helmet” to “Unicycle, Standard
See my last post in this thread for the exact definition by the IUF :roll_eyes: It’s pretty clearly defined.
Here is the IUF Rulebook Committee 2018 Definition of Unicycle, Standard
Yet current definitions are still controversial and remain under discussion.
And I thought I had asked a simple question!
The term “standard unicycle” has two different meanings:
  1. The official meaning in 1D.1, which I quote in full:
    A Standard Unicycle has only one wheel. It is driven by crank arms directly attached to the wheel’s axle/hub, with no gearing or additional drive system. Pedals and cranks rotate to power the wheel. Is balanced and controlled by the rider only, with no additional support devices. Brakes and extended handles/handlebars are permitted. For some events, such as track racing, standard unicycles have restrictions on wheel size and/or crank arm length. Other events may specify other restrictions. When not noted otherwise, there are no size limitations.
  2. The colloquial meaning: any unicycle that permits the rider to start in most track races, and in the Standard Class (versus Unlimited Class) in Road Races.
(Strictly speaking, “Standard Class” is not a thing. But everyone uses that word.)
These two meanings are conflicting.
Honestly, I don’t see much need to redesign the rules. Instead, we should be starting to always add the wheelsize to the “Standard” category when using it in events. If the usual “standard class” in a marathon would be called “standard 29” ", and there would be “standard 24” and “standard 29” in a 10 km race, it would be a bit more intuitive to people not familiar.
It’s honestly never really hard to find out which category your unicycle fits in races either way…
“Standard” has become a lousy word for unicycles, because of too many uses and situations. The term “Standard Class” comes from a form of trick-riding competition that went away before the turn of the century. Later versions of that were Open-X and now X-Style. There was also the Standard Skill event, but the use of “Standard” in that referred to the standardized list of tricks that were available to use in your routine, each worth a fixed amount of points if you did them flawlessly.
The uni competition events that are the oldest tend to have the most detailed rules. Somebody always questions something that we all took for granted, but they didn’t know about it because they’re new to the sport and have no local unicyclists. So we keep getting more specific. The rules for newer events, like Flatland and platform jumps, are much more free, and much easier to work on!
Anyway, the IUF Rulebook Committee is currently voting on the final proposals for changes to the Rulebook for Unicon 20, 2020 in Grenobe, France. If that link above this thread works (not sure if you have to be a member), here’s the proposal for updated definitions for Unicycle, Regular Unicycle and Geared Unicycle. “Regular” basically replaces “Standard” in describing a unicycle that’s not a giraffe, more or less. 14 yes votes out of 23, nobody voted no or abstain yet.
Meanwhile, we also did some slight modifications to the wheel/crank definitions (for Track), to eliminate gray areas. Note that each size now has a minimum diameter. For most situations this isn’t needed; it’s only for events where smaller wheels are not allowed, like races over 20km.
I’m not sure if anything will change for the larger 24" size for Basketball and Hockey, since they now both share that definition, in two separate committees, which makes it harder to work on rule changes…
For both of those proposals, you can click the links at the bottoms of the pages to see the discussion that lead to the final proposals.
Be cautious when using published tire width sizes to make assumptions about how accurate they aren’t. I think in the Road biking world, especially, these numbers are pretty accurate. But as tires get wider, they seem to be fairly fluid; some much more than others. While the BSD has to be accurate for a tire to fit the rim, width sizes are often “inflated” or otherwise inaccurate. The only way to really know is to try the tire on the rim in question and pump it up to “working” pressure. :frowning:
Speaking of BSD (bead seat diameter of a rim), we moved toward it for a while in unicycling, but then away again. The problem is, very few rims have the BSD marked on them. And more tires do, but not all. So there’s no way to confirm a legal-sized wheel at the track. So for now, we’re still using “the box”, a box that’s the specific size of maximum diameter. If your wheel fits in without rubbing, it’s legal. Some day we might return to BSD for wheel sizes in some events, but probably not Track, where the diameter is crucial.
Endlessly. :smiley: Hopefully the new definitions will stand the tests of time better…
As mentioned earlier, the actual side-to-side width is not restricted, but that number also approximates the “tallness” of a tire above the rim. A larger “width” makes for a larger diameter. Very few 24" tires are actually 24" in diameter! The old Schwinn tires were pretty close. The Miyata tires were smaller, and the old 3" Gazzalodi tire on my Wilder Muni was close to 26".
Basketball and Hockey use a less restrictive size for their 24" wheels, in order to accomodate the thicker tires that are common among players, and also common in the shrinking market for 24" tires. I recently had a bit of a panic when I couldn’t find ANY decent tires online to use as a replacement on my old Miyata. UDC only had a Muni tire, and Amazon had a slightly knobby one that probably wouldn’t roll as well. Everything else was too thick for the Track! If that trend continues, we may have to relax the maximum size for Track, but this will upset a lot of people because the older speed records would lose their status of currency. One by one they would fall. But isn’t that what records are supposed to do, be broken?
That would be the last thing unicyclists would want. Well, maybe Track racers; a pretty serious bunch. But the main restrictions for Track are maximum wheel diameter and minimum crank length. When we started adding races for other unicycle types (Muni and Road) we tried to avoid restrictions in order to let the riders, and the market, figure out what works best. So Muni and Road unicycles have less restrictions on them, whereas Track racing wants a more level playing field.
Absolutely! Especially if it’s far enough that you flew your unicycles there. That’s why we have to be very specific about those dimensions in the Rulebook. I’ve seen many people find out the hard way that their tires were a tiny bit too big (usually skinny 26ers), or a lot too big (the basketball-type tires).
I thend to agree with you. But people are nit-pickers. Also, sometimes we have to change things to fit the “now”, like a dwindling market for 24 x 1.75" tires, for example.
Now nearly a year later I finally bought a 24" uni:
So many considerations. I really like the orange 24 muni they have, but to be real, I don’t ride wild muni tracks and would just take the 26" or 29" and if I do want to participate in the Dutch Championships again, I would at least need an additional wheel that complies to IUF rules. Though I very much like Nimbus, I think the QUAX has a good price. Not too cheap and not too expensive and a strong road tire, so I can also use it to learn some other techniques.
Now the only sizes I don’t have are the 27.5" and 43", though I don’t see the point in getting those. Also once tried sitting on a giraffe, but I thought it was too high. I would prolly break my feet when UPD-ing it. Now with ±11 unis I think the collection is complete for me :smiley:
I recently bought a KH27.5 Muni so I didn’t have to swap wheels on my 29 between road and off-road.
The tyre on the 27.5 makes it almost the same diameter as the old 29. In fact my old KH29 fork only has five millimetres of extra clearance over the 27.5 fork.
I once thought nine unis was about right but now have nineteen wheels.:o Some share frames. Two wheels are UWs which are interesting to try but seemingly implausible. There is a Nimbus 5’ giraffe bought cheaply that I saved from neglect along with a little Club 20 thrown in.
My largest is a 36. I don’t have a 32, 16 or 12.
