Installing brakes
Hey all, I was looking through my Bike Nashbar catalog today when I had an
inspiration. Would it be possible to clamp a single bar end to the
seatpost? That bar end could have a brake lever mounted on it and/or a
cycle computer. I was thinking that it could stick out forward just under
the seat. Has anyone done this yet? The only problem is if the diameter of
your seatpost is not the same as that of the average handlebar; although,
if needed, shims could be used.
Jeff
GET INTERNET ACCESS FROM JUNO! Juno offers FREE or PREMIUM Internet access
for less! Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
Re: Installing brakes
Yes. I attached a bar end to my seat post to attach a brake lever. It fit
great. The brake lever ended up about 5 inches below the seat, but it
should be easy to move closer to the seat if desired. -Mark — jeff d
> an inspiration. Would it be possible to clamp a single bar end to the
> under the seat. Has anyone done this yet? The only problem is if the
> diameter of your seatpost is not the same as that of the average
> handlebar; although, if needed, shims could be used.
> Jeff
> access for less! Join Juno today! For your FREE software, visit:
Do You Yahoo!? Yahoo! Auctions - buy the things you want at great prices
http://auctions.yahoo.com/
> fit great. The brake lever ended up about 5 inches below the seat, but
> it should be easy to move closer to the seat if desired. -Mark
Got any pictures? I would love to see them.
Chris
No. Sorry. I’ve removed the set-up bc I was more afraid of my brake than
the hills I ride. I guess it worked too good. -Mark — Chris
> attach a
> > brake lever. It fit great. The brake lever ended
> up
> > about 5 inches below the seat, but it should be
> easy
> Chris
RE: Installing brakes
Concerning brakes…
Is there any trick used in Muni (trial ?) adapted for specific obstacles ?
(apart of downhill muscle activity relief)
Oli-
-----Original Message----- From: jeff d tuttle
[mailto:moosebreath1@juno.com] Sent: Tuesday, April 17, 2001 10:01 AM To:
unicycling@winternet.com Subject: Installing brakes
Jeff
Mark, What kind of seat post did you use? Did the bar end fit well, or did
it require some work? -Jeff
On Tue, 17 Apr 2001 08:43:22 -0700 (PDT) mark stephens
<markastephens_2000@yahoo.com> writes:
> it should be easy to move closer to the seat if desired. -Mark — jeff
> > had an inspiration. Would it be possible to clamp a single bar end to
> > the seatpost? That bar end could have a brake lever mounted on it
> > and/or a cycle computer. I was thinking that it could stick out
> > forward just under the seat. Has anyone done this yet? The only
> > problem is if the diameter of your seatpost is not the same as that of
> > the average handlebar; although, if needed, shims could be used.
> > Jeff
> ________________________________________________________________
It was the Semcycle seat post. The one without the holes. I think it’s
about the same size as Miyata & some others. The bar end fit well. My
problem was that I had the wrong type of brake ?? for what I wanted to do,
which was to give my legs some relief on steep downhills. (On paved roads
> did it require some work? -Jeff
> attach a
> up
> easy
> > to move closer to the seat if desired. -Mark — jeff d tuttle
> single
> > > bar end to the seatpost? That bar end could have a brake lever
> > > mounted on it and/or a cycle computer. I was thinking that it could
> stick
> > > out forward just under the seat. Has anyone done this yet? The only
> problem
> > > is if the diameter of your seatpost is not the same as that of the
> > > Jeff
> prices
Mark, I had seen a picture (http://www.unicycling.com/garage/special.htm)
where instead of a conventional bicycle break lever a gear-shifting lever
for a road bike was used. This way it could be set to a certain degree of
friction for descents. I think it was used by some group who crossed the
alps. Does anyone have more info about this? John Foss? Jeff
On Tue, 17 Apr 2001 11:56:45 -0700 (PDT) mark stephens
> do, which was to give my legs some relief on steep downhills. (On paved
> > attach a
> > up
> > easy
> > > > I had an inspiration. Would it be possible to clamp a
> > single
> > > > could
> > stick
> > > > only
> > problem
> > > > Jeff
> > > > Internet access for less! Join Juno today! For your FREE software,
> > > > visit: http://dl.www.juno.com/get/tagj.
> > prices
> instead of a conventional bicycle break lever a gear-shifting lever for
> the alps.
Wolfgang Stroessner was one of those riders, and he has some content about
it on his Web site. The site uses frames so I can’t link you all the way
there, but start here:
http://www.unicycling.de/
Then click on “Einrad,” then “Mit dem Einrad uber die Alpen” (or
optionally switch to English first) :slight_smile:
Stay on top, John Foss, the Uni-Cyclone jfoss@unicycling.com
www.unicycling.com
“I’m gonna wash that man right out of my sheets…” – sung by a female
friend, doing laundry after breaking up with a short-term boyfriend
Bar end with gear lever is used extensively in the UK. There is a picture
of the one fitted to my Coker at:
http://www.unicycle.uk.com/faq.html#Brake
it is not a brilliant picture but I think you will get the idea. I prefer
to be able to see my computer when I am riding so my bar end faces down. I
know that others prefer the lever right under the handle so they have it
facing up. The only problem you will have is that the bar end levers are
designed for a narrower bar than the bar ends so requires some packing (I
just rolled some card board up and put it in)
Roger
The UK's Unicycle Source <a href="http://www.unicycle.uk.com/">http://www.unicycle.uk.com/</a>
----- Original Message ----- From: “jeff d tuttle” <moosebreath1@juno.com>
To: <markastephens_2000@yahoo.com>; <unicycling@winternet.com> Sent:
Tuesday, April 17, 2001 7:27 PM Subject: Re: Installing brakes
> > > to the seatpost? That bar end could have a brake lever mounted on it
> > > of the average handlebar; although, if needed, shims could be used.
> > > Jeff
> > prices http://auctions.yahoo.com/
You can find bar ends that will fit a standard Miyata seat post. I used
one on my Muni for a brake mount.
There are also nobs that are designed to mount a cycle computer on aero
bars. An example of one is at
http://www.performancebike.com/shop/Profile.html?SKU=3645&Store=Bike There
are other brands too that are a little longer. A combination of a bar end
and a nob would be a good way to mount a computer on a Coker. Or you could
just use a nob by itself.
john_childs
>From: jeff d tuttle <moosebreath1@juno.com>
>of your seatpost is not the same as that of the average handlebar;
>Jeff
Get your FREE download of MSN Explorer at http://explorer.msn.com
Got Pictures?
> There are other brands too that are a little longer. A combination of a
> bar end and a nob would be a good way to mount a computer on a Coker. Or
> you could just use a nob by itself.
> john_childs
> >Jeff
> _________________________________________________________________
There are some situations where a brake on a muni can be useful. For
example, when you want to hop up a steep incline while keeping the wheel
pointed straight up the incline. Normally you would turn sideways to the
incline to make the jumping easier, but sometimes that is not practical or
possible. In that situation locking up the wheel with the brake can be
helpful. In trials you can run into this situation when trying to hop up a
steep narrow beam. But jumping up an incline with the wheel locked like
that is not easy (it’s beyond my skills).
john_childs
>From: “Olivier Paugam” <opaugam@aptilon.com>
>Concerning brakes…
>? (apart of downhill muscle activity relief)
>Oli-
