Any recommendations on which bearings to use on the Impact Reagent Pro or Impact Gravity Pro frame?
I’ve seen unicycle shops selling wide bearings 22x32x14 (needle?) bearings and slim (ball?) bearings 22x32x7 of which you use two per side.
no needle, twin rows
14mm bearing is better than 2 bearings of 7mm
Thanks.
Damn, I am only able to find the slim bearings in European unicycle shops, only in UK, no bearings at all in EU shops.
Any sources known, especially for the wider ones?
this is a specific bearing made by KUE-Q in Taïwan
Really ? Did you ask to Municycle ?
Yes. Estimated availability: mid 2023.
