I would do anything for a Kris Holm 2007 trials except pay 500 bucks… i cant afford a 500 dollar item!
Why don’t you go buy a DX then?
i cant afford it either that was the one i was planning on buying but i cant afford it:(
I recommend suicide.
If you can’t unicycle, there is no point in life.
Haha, well i have my 20" sun (i just bent the axle slightly) and im planning on purchasing a tirals wheel set for it with my bday money http://unicycle.com/shopping/shopexd.asp?id=798 i want this…and im still looking for a 48 spoke trials rim to go with it
Don’t get the 48h setup.
Just pay the little extra for the Kris Holm Moments.
Trust me, you will regret going with a 48h setup.
Oh! ok… thanks
can you send the link for the hub please?
I also didn’t mention that those only come in 170mm cranks… which is extremely huge for a trials unicycle.
The new Kris Holm Moments are not on Unicycle.com for a while now…
You can get them from Bedford though, for $195 CAD + Shipping.
$166.40 is the exchange, but I’m sure Darren will charge differently.
http://unicycle.com/shopping/shopexd.asp?id=658
what about this?
You can only get 140mm or 170mm cranks for that.
Plus it’s very expensive.
The Kris Holm Moments were $136 for Hub and Cranks, along with all the hardware you need to put them together.
ok well thank you very much i really appreciate the help!
-Andrew
Qu-Ax make a 125mm crank for this hub, as used on the nimbus hoppley.
Probably still expensive though.
Whoa 170s on a trial just doesn’t seem right
im sure if you kept posting such crap threads enough, somebody would buy you one to shut you up.
You talking about me??
Maybe we should create a forum section dedicated to Dunawan threads. He does seem to create about a hundred a day.
