My name is robin i live really close to shadowuni and ride with him often he got me into uniing i learned on a 20" torker lx then a few monthes l8er i got a 26 that is pretty sweet. hookworm, yuni frame kh seat, DX 32 rim yeh pretty much a sweet uni. I was justr wondering whats the best way to getting the hang of idling becuz i can pretty much freemount into it but i can only keep it up for about 15 seconds.
Re: IM NEW to RSU
Step 1: Learn to type.
Step 2: Buy cotton socks.
Edit: I know him.
Re: Re: IM NEW to RSU
Sorry, that was the monkey I trained to be rude to new members, Rob. His name is Willy! Check him out on my awesome computer!
OK. Idling. Easy stuff. Tips:
Practice much.
Concentrate on keeping your bodyweight on the saddle.
Keep your weight in one spot and swing the uni back and forth beneath you by pedaling. The unicycle should move to correct balance faults, not you.
Keep movements smooth. Plan ahead and make sure you don’t overcompensate.
Don’t worry so much about forward and back balance. More important is side to side corrections.
If you fall left make the wheel go left.
tanks kevo
One way learning ideling is going forward, stop, pedal back half a revolution, and start going forward again. Try again, try again, try to make more than one pedal. next time.
Do this with your strong foot down.
i’m pretty much doing that now, i have enough control to come to a complete stop then do 1/2 rev. backwards and sometimes i can manage to get going forward again. so basically i just need to practice more ok kool
as soon as the snow is not too thick ui can practice more.
Don’t make the idles too big. At least I find it not neccesary to do biiiiiiig idles. Do them slow and controlled if you can. Not too fast or it will through off your balance.
-Lee
that makes alot of sense thanks
Welcome to the board. Feel free to Private Message me (under the user cp button in the top right corner) or message me on AOL IM if I can do anything to ease your travels.
Stay on top and Stay true.
Adam
SN: Accord442
You might want to have a look at www.unicycle.2ya.com too for some tips and video tutorial, and other stuff.
Andrew
Re: IM NEW to RSU
(Quoted from Learning to Unicycle, by Andrew Carter and me)
Idling - Idling is riding half revolutions forward and backwards
repeatedly, effectively staying on the spot. Learning to idle may take
quite a while and can be very frustrating, however it is an extremely
important skill. Firstly, you will often find yourself in a situation
where you’re riding and need to stop for some reason but want to stay
on the unicycle. This is where idling is very useful. Secondly and
possibly even more importantly, the coordination you develop in
learning to idle is needed for many more advanced skills and will give
you a much greater control of the unicycle.
· In the “Learning the basics” chapter we have described
“Rocking on the spot” while holding onto a support. In it, the cranks
oscillate around the horizontal position. If this is done without
support it is called “Horizontal Idling”. This is more difficult than
normal idling, which involves oscillating the cranks around the
vertical position.
· To start learning (normal) idling, sit on the unicycle beside
a support with the cranks horizontal. Hold on to your support with one
or both hands. Lean slightly forward while keeping the wheel
stationary for a little while. Then pedal forward for half a rotation,
at the end of which you should be leaning slightly backward.
Immediately after the forward half rotation, pedal a half rotation
backwards, at the end of which you should be slightly leaning forward
again, so you can rightaway start the next idling cycle.
· Focus on using a pendulum motion as opposed to moving your
whole body back and forth. That is, your body should ideally stay
more or less in the same place, while the wheel “swings” forward and
backward under you. Remember to keep your upper body straight and
upright and to keep your weight on the seat. Your leading (or
“strong”) foot should be on the bottom and move back and forth past
the 6 o’clock position.
· Try to maintain forwards/backwards balance by adjusting the
timing and power of your pedal strokes, as opposed to pushing the
support. It is OK to use the support for sideways balance for now, but
try to push and pull as lightly as possible.
· If you idle too slowly it will be more difficult to maintain
balance. On a 20" wheel the idling frequency should be about 1 per
second, on a 24" wheel it is usually somewhat less.
· Now it’s time to leave your support. Ride forwards in the
open, not too fast. Slow down while leaning back, throw in one half
revolution backwards, during which you should regain your forward
lean. Then continue riding forward. Repeat.
· If you are somewhat solid at throwing in single idles, try
inserting two idling cycles at once, then three, etc.
· The greatest difficulty is usually found in controlling the
side to side balance. Focus on keeping the unicycle under you rather
than you staying on top of the uni. If you find yourself leaning too
far to the right, you must move the wheel to the right to keep it
underneath you. To do this, twist your lower body to the right as the
wheel rolls forward and to the left as the wheel rolls backwards.
That way, you turn the whole unicycle by the seat.
Klaas Bil - Newsgroup Addict
It’s impossible to get old when you ride a unicycle - John (what’s in a name) Childs
