I am trying to learn how to idle, but am having some trouble. Every time I try to pedal backwards, the uni just moves in some random direction or just falls out from under me. Any advice on idling?
Jason
Jason
Re: Idling
Are you holding onto something? If not, try it. Particularly at first, if available, a place where you can hold onto something with both hands. This will help you get the feel. Don’t rely on holding on for too long, but it should help you get started.
Keep at it, idling is very important.
Good luck,
Raphael Lasar
Matawan, NJ
use the search feature, and try learning backwards to get comfortable with the pedaling direction. if you havent done the level 3 “ride forward, stop, pedal 1/2 revolution backwards, continue forwards” you might want to master that. it’s a good way to bridge the gap.
