Identify the Rider - Speedster 36er
Well he might need a brake! But he might also need a handle for that brake…
If you look carefully though that brake is sideways and will squeeze the tire instead of the rim. It would probably be easier to remove then rotate.
I hadn’t spotted that. Yes, I should remove it. I had allowed the assumption that the lever is hidden somewhere under his hands.
