Idea for learning skinny riding
I was thinking of getting a 10 foot piece of 1.5 or 2 inch PVC pipe and having it cut in two length wise… This would give me a chance to ride skinny without being 4 feet off the ground…
Feasible idea? Any other ideas?
I just want to learn so that if I am out on the Muni and have to negotiate along a down tree, I can… NOT about to pull a Kris Holm bridge riding thing! :astonished:
just get like four 10’ 2x6’s and some strong wood screws and drill em together into a square. so then you can even practice turns.
or 2x4’s, whatever.
not being able to edit only 10 mins after posting is a joke.
or 2x4’s, whatever.
and then you can add whatever you want on the top. i wouldn’t recommend pvc pipe, i’ve never used it because i think it’ll break.
i have 2x6s, just on saw horses for height…one has a metal fence pole screwed on top. 2 others have 2x2s drilled on so it’s diamond shaped. sand one edge of the 2x2 so it will sit on the 2x6, then put a few screws in. my other 2 skinnies have wooden dowels screwed on (by far the most expensive…)
2x2s or metal pole is the best. my neighbor had some metal pole layin around. an 8 foot section of non pressure treated 2x2 is only 2$ though(home depot), and that makes for a really pointy skinny…
another option is a 4x4 for a really pointy skinny. make something (you can probably make some ghetto crap from wood laying around the house) for the 4x4 to sit in diagonally , like this. i wouldn’t worry about strapping it down since it wont be high.
http://www.youtube.com/watch?v=_EWwps5TRmg
the most challenging, most slippery is metal pole tho. you can get fencing for about $8-10 for a 8-10 foot section at home depot.
