i took my truck mud bogging today
and now the engine is making a squeaking noise when its started. Does anyone know why? and can i fix it myself and if not how much it wuld cost to get fixed? and is it even that big of a deal?
Check all of your belts, You might have a loose one. Does it only squeak when you start it, or does it squeak until you stop the engine?
Could be any number of things though.
Edd
it squeaks the hole time when its running and when its starting
Same thing happened to my dads truck. It was his CV joints giving out.
It could still be a number of things.
some of the oil on somthing could have got washed away?
>If it were the CV joints then it would only happen if the truck was moving not just running.
@brendon557 don’t you know that’s what a dune buggy is for not your truck :stuck_out_tongue:
Edit: this might be something better to post in a auto forum :wink:
tighten the flywheel and it should stop.:slight_smile:
Wow… some interesting answers so far.
Probably just need to oil the muffler bearings. :roll_eyes:
Does it squeak when you’re sitting still with the motor running or just when you actually drive it?
If it’s just when the motor is running, could just be belts. They got dirty in the mud and now either need to be cleaned or replaced. You can try just some water while the motor runs.
If it’s while it’s rolling, it could be lots of stuff, but I’d check the brakes for mud/dirt first. Depends on what the squeak sounds like.
Thats a good one need to remember that :smiley:
I could probably fool a LOT of people I know. I was talking to this chick the other day about how when I was learning to drive a manual I killed it when I tried to start up in 3rd and she was like…So what’s 3rd gear? Priceless :stuck_out_tongue:
hey if you buy me a dune buggy id be more then willing to take it out for you :stuck_out_tongue:
ok i noticed a few things about the noise
i cleaned the engine out and i popped the hood and when it starts squeaking i spray the belt/fan area with the hose and the noise goes away but when i turn the car off then back on it comes back
also
the noise leaves when im accelerating
Fan/alternater belt then. Tighten it up a bit and see if it stops the squeaking.
Edd
Yeah, sounds like a belt.
You’re welcome :smiley:
I’ll make you one first thing tomorrow. if you belive this I have some oceon front property for sale 15 miles from me.
