I need mesures (saddle)
I am doing myself my uni, cause it isnt common here in Brazil. So I need to do all myself, there isnt in stores.
I almost finished, lack the saddle.
I cut a tire to do it, but I need the measures to make it.
Can somebody help me, with mesures? Dont need be exact.
Pics also help me.
After done I shall send a pic on forun.
Tank you!
Flavio M.
oiacoitado@hotmail.com
Here are patterns to make a seat cover, it might help you out. I’m not good at making things, but I did make a seat cover following these patterns and it worked good.
tank you.
Is good, I printed but just lack scale.
How is the maximus mesure, point to point, only to I find out the scale and apply to others mesures?
Tank U
These were scanned from two US letter sized pages (8.5 X 11 inch or 216 X 279 mm). Also, there are two marks that will be one inch apart on the upper registration line when the pages are properly aligned.
I ought to know, I’m the one that scanned them.
Note that this cover was designed for an air seat. For links to Krashin Kenny’s air seat designs:
The Cheap one , this one is very easy and very inexpensive, just a sock and and innertube
The one this design was for
I hope this helps you, my air seat is fantastic, I like Krashin` Kennys design.
This pattern Gobd posted was my design to be used as an air saddle cover originally. It will work with foam padding also.
Here are the measurements from the original pattern:
Top cover:
Front to back =30 centimeters
Width at front= 10 centimeters
Width at back=14 centimeters
Side cover (2 pieces):
Length along curved bottom edge= 46 centimeters
Length along curved top edge= 39 centimeters
Height= 10-11 centimeters (cut the excess material from this section depending on the thickness of the pad/innertube as necessary)
On Thu, 23 Dec 2004 16:30:13 -0600, “fcandeias” wrote:
>I am doing myself my uni, cause it isn`t common here in Brazil.
About two years ago, a guy by the name of Eduardo Lourenço Pinto Jr. built his own unicycle in Brazil because he couldn’t find any in the shops. Only later he found out that there is in fact a unicycle factory in Brazil, and he bought a saddle from them.
Eduardo’s website: <http://www.ype.unicyclist.com/>.
The factory: <http://www.monociclo.com.br/>.
Old threads: Search!
Hope this helps.
Klaas Bil
(reposted on the forum because of a problem with my news server)
Re: I need mesures (saddle)
Hope this helps.
Klaas Bil - Newsgroup Addict
“Deflating pi does not reduce calories, it just concentrates them. - billham”
