So have you ever noticed how often the mouthpiece of your hydration bladder tube drags on the ground when you take off your pack or sits on your floormat in the back of your car when you throw you stuff in after a ride?
What do you use to keep the mouthpiece clean and protected?
I use the rather low tech system or strapping a bit of plastic over the mouthpiece and securing it with a rubber band but I wouldnāt mind some slightly more sophisicated ideas.
yeah I donāt think a bit of dirt is gonna hurt, I usually dont worry about it or just try keep the mouth piece off the ground. Crikey that plastic sounds very sophisticated to me!
I place the tube and mouth piece inside the compartment where the bladder lives. On my camel back I open up the top velcro, place the mouth piece end of the tube inside and seal it back up.
I just got a new pack with a zippered compartment where the bladder is, and will do the same with that.
The Camelbak Thermal Control Kit may be what you are looking for. Itās a bit pricey though. If you are that worried about it, you could try cutting a finger off a latex exam glove and cover the bite valve with it.
Thanks for the suggestions about the mouthpiece coverā¦I didnāt know they made them, I think Iāll get one. They should come standard with every hydration pack, in future, I figure.
