hub weights
Is there a list of the various hub/crank weights around?
Profile; KH; Onza; quax; suzue with alloy/steel cranks; other?
cheers
Nick
According to wobbling.unicyclist.com Profile hubs are 565g and Suzues are 370g. Profile cranks are 588g per pair (not sure which length was measured).
+0][y
Tony,
Do you know how much the UDC hub weighs? I forgot to weigh it before sticking it on my Coker
Ken
The Qu-ax hub WITH 145 mm cranks weighs 1400 grams or 3.06 lbs. Try going directly to Municycle.com and ask via email what the hub, alone weighs. I would also call unicycle.com and ask them to throw a KH hub on a scale for you.
Hi,
the Qu-ax hub incl. bearing weights 660g.
Roland
Here is a related thread:
http://www.unicyclist.com/forums/showthread.php?s=&threadid=31801
